Vacuum
Old Dec 8, 2010 | 01:53 PM
Ant1981's Avatar
Ant1981
Default Vacuum
Is there a good guide around that will show up every vacuum hose and connection?
I need to check mine to get the cruise and heater flaps working again, since the head gaskets being changed on my '85, they don't work!
Old Dec 8, 2010 | 03:03 PM
pcolt94's Avatar
pcolt94
FSM - Factory service manual. I would use this for accuracy. Aftermarket repair books (Haynes) may or may not tell you what you what to know.
However I would look at the check valve on the right side of the engine, (if you have one on the 85) to, under plastic cover to see if it is broken or cracked (3 hoses to it).
Old Dec 8, 2010 | 04:07 PM
hooked073's Avatar
hooked073
should be a decal under your hood.
Old Dec 8, 2010 | 04:52 PM
pcolt94's Avatar
pcolt94
That would be good to.
Nice Hat.
To Vacuum
