eandmy
Old Dec 9, 2010 | 11:55 AM
eandmy's Avatar
eandmy
Default eandmy
help
cooling fan stoped working over heating what to do
Old Dec 10, 2010 | 06:52 AM
ex-x-fire's Avatar
ex-x-fire
What year? You need to check if the fan is getting power & ground. Use a 12 volt test light or multimeter. Check the relay connection as they been known to melt or get corroded. There should be a switch in the head that activates the relay, do a continuity test between the fan & the relay, the relay & the switch, the relay & the battery.
