Difficulty Pushing In Auto Gearshift Selector Button
Old Dec 9, 2010 | 08:46 PM
95BLKVette's Avatar
95BLKVette
Default Difficulty Pushing In Auto Gearshift Selector Button
Has anyone ever had a problem in pusing in the button on your automtic transmission gear selector?
I know you have to depress the brake pedal first as there is some type of lockout mechanism.
Problem is it has been getting more and more difficult to push in the selector button that allows you to move the gearshift selector
Sometime I have to use two hands and other times it seems to work just fine.
Don't want to get stuck someday casue I can't put it in gear
Old Dec 9, 2010 | 09:04 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
Id like to know this my self
Mine acts up only when it gets cold
Old Dec 9, 2010 | 09:13 PM
95BLKVette's Avatar
95BLKVette
I read some old posts, and they all say the same thing for 94-96 models. We have an electric solenoid connected to a switch on the brake pedal.
When the solenoid is on the way out, it begins to stick.
They say you have to remove the button, gearshift ****, and center rear armrest/console cover and then remove the gearshift cover assembly. Next remove the two wire clip to the solenoid and pop off the two solenoid ends and remove the entire solenoid. We will never have the problem again. BTW, they don't stock or manufacture the solenoid anymore
Old Dec 9, 2010 | 09:23 PM
RICEKILA's Avatar
RICEKILA
Way to involved -- I'll just keep using the hammer
Old Dec 9, 2010 | 09:37 PM
95BLKVette's Avatar
95BLKVette
Sorry but the damned hammer is stuck too!
Old Dec 9, 2010 | 10:57 PM
aminnich's Avatar
aminnich
This is the solenoid:
Old Dec 9, 2010 | 11:42 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
That solenoid is part of your anti-theft aparatus. Just get another one at a wrecking yard.
Looks like a $6 used part to me
Old Dec 10, 2010 | 09:19 AM
hooked073's Avatar
hooked073
it is because of the colder weather. you can remove it and forget about it. Somthimes you can lube it with WD40 that helps. GM sells them they are not to much.
Old Dec 10, 2010 | 09:24 AM
anciano's Avatar
anciano
This question also came up on another forum.
Both the owners manual and the FSM have something to say about this, and it's not about the solenoid. They say that the parking pawl in the trans can become jammed if you park on a hill without using the parking brake. In extreme cases they say you may need a PUSH to free up the pawl. It's indexed under "shifting out of park" in the owners manual.
So the solenoid might be your problem, but not necessarily so.
Old Dec 10, 2010 | 05:42 PM
hooked073's Avatar
hooked073
parking paw will not effect pushing in the release button. parking paw may cause you to not be able to shift out of park after after you push in the button because of the load you put on it. The parking paw has been in every automatic that I can recall from all manfactures. except heave duty. The brake interlock was mandated by the feds in the middle 80's for all manfactures to have so you have to have your foot on the brake before shifting. This was a safty measure.
Old Dec 10, 2010 | 06:31 PM
RICEKILA's Avatar
RICEKILA
Maybe I'll pop off the leather-ish material and spray it with silicone and or white grease short of finding the chisel
Old Dec 10, 2010 | 06:51 PM
hooked073's Avatar
hooked073
Use wd40 or something close to that spray the linkage that it activates also work it a few times so the lub can work itself in.
Old Dec 11, 2010 | 12:29 PM
RICEKILA's Avatar
RICEKILA
Originally Posted by hooked073
work it a few times so the lube can work itself in.
I love when you talk like that
Old Dec 11, 2010 | 12:56 PM
hooked073's Avatar
hooked073
funny **** man
Old Dec 12, 2010 | 05:02 PM
markKlein's Avatar
markKlein
That is not an anti theft device, it is the "brake engaged" solenoid. They go bad, you cannot buy new ones. Perform the removal procedures outlined above and your problem will be solved. It is not that hard. The important thing is to pop it loose and remove it, some people gety lazy and just disconnect it; that will just make the problem worse. WD40 will provide a temporary solution at best, do you really want to be stranded when it finally stops working altogether?
Old Dec 12, 2010 | 05:44 PM
hooked073's Avatar
hooked073
A friend got one in stock from a dealer about 6 months may be he was lucky course it was not bad like I told him. And yes very easy to remove but is also a safty function and can cause a failed state inspection depending on where you live. The WD 40 cleans and lubes the linkage and shaft to the soleniod. These things seldom fail but get gunked up and in winter get sticky. Usaly clean everything good and you are fine for another year or 2.
Old Dec 12, 2010 | 06:51 PM
95BLKVette's Avatar
95BLKVette
I took my BTSI solenoid out today. The ends pop off the riveted ball ends very easily with a screwdriver.
I tried lubing the solenoid shaft to see if it was binding, but that's not the problem.
I also checked for 12V when ignition is on and off when brake pedal is depressed....that checked out fine.
I took the solenoid apart and found just a round steel plate mounted to the actuator shaft that is held fast to an electromagentic coil when it is energized. Problem is that over time it appears the electromagnet becomes slightly magnetized and the damned plate sticks to the coil.
I've taken mine out for the time being and will be looking for a replacement coil assembly to swap into the existing plastic case.
To Difficulty Pushing In Auto Gearshift Selector Button
Old Dec 12, 2010 | 06:53 PM
albertlsmith's Avatar
albertlsmith
I've had my 95' for ten years and it has always done that, but only when starting the first time of the day. I had no idea that a solenoid could be involved. I will check on that, and thanks guys!
Old Dec 13, 2010 | 09:14 PM
95BLKVette's Avatar
95BLKVette
So tonight I decided to take the coil and steel core assembly out of the plastic housing and rub it on my small demagnitizer I purchased from Harbor Freight a while ago.
Put it back together and the shaft doesn't stick any longer!
I will have to check it with a 12V voltage applied on and off a couple of times and see if it no longer sticks.
If that's the case, then demaginitizing the coil is the fix
Old Dec 14, 2010 | 08:25 AM
anciano's Avatar
anciano
That's interesting. I pulled mine based on this thread and found the plunger to be completely free-moving in the housing. When I put 12V to it the plunger neither retracted when out or extended when in. I might mess with it some more before dissecting it. How did you open the housing without destroying it?
