'91 Shoots ducks
Old Dec 13, 2010 | 03:52 PM
htrdbmr's Avatar
htrdbmr
Default '91 Shoots ducks
Recently my '91 started falling apart at 4900-5000. I replaced the cap and rotor, (cap was really bad). Now there is no popping and banging but it is like there is a governor coming in, it just goes soft. I've had the car for 18k miles, never replaced the coil or module, but the wires are new. There are no stored codes. Should I replace more ignition parts, or look in other directions? (fuel pressure is solid at 42 psi at point of failure)
Old Dec 13, 2010 | 04:12 PM
383vett's Avatar
383vett
I'd go fuel filter and plugs next.
Old Dec 13, 2010 | 06:47 PM
ch@0s's Avatar
ch@0s
You hit the TPI wall my friend.
Get one of these
Old Dec 13, 2010 | 06:55 PM
twin540's Avatar
twin540
Old Dec 15, 2010 | 12:14 PM
htrdbmr's Avatar
htrdbmr
Get one of these
This is a new issue, previously the shift to 2nd at WOT would rattle teeth. Now it doesn't shift because the RPM drops off. As previously stated, fuel pressure is good, so filter must be good. What is the failure symptom of the coil, or module aside from an obvious no-go? Thanks for the replies.
Old Dec 15, 2010 | 12:53 PM
ch@0s's Avatar
ch@0s
I agree with the others this kind of sound more fuel related. But you say you have checked the fuel system. I has a similar problem once and it turned out to be the cats. They were clogged. Have you checked the cats yet.
Old Dec 15, 2010 | 04:04 PM
htrdbmr's Avatar
htrdbmr
No cats.
To '91 Shoots ducks
