Freezing Door Seals
Old Dec 14, 2010 | 11:42 AM
92WhiteVetteGuy's Avatar
92WhiteVetteGuy
Default Freezing Door Seals
Hi,
I use my 92 LT1 Coupe as a daily driver.
What can I put on the door seals to prevent them from freezing shut?
Thanks,
Old Dec 14, 2010 | 11:56 AM
Ant1981's Avatar
Ant1981
Happens on mine too. Get some weather strip conditioner and apply that a few times a week or when you feel necessary.
Old Dec 14, 2010 | 12:08 PM
jon0108's Avatar
jon0108
dielectric grease. rub it on with your fingers, wipe off excess
Old Dec 14, 2010 | 12:23 PM
samsonb's Avatar
samsonb
Probably wax the car as well where the weatherstripping touches the body.
Maybe the weatherstripping on the door is worn?
Old Dec 14, 2010 | 01:04 PM
MyFirst90coupe's Avatar
MyFirst90coupe
I've always heard that silicone spray on the weatherstripping works too.
Old Dec 14, 2010 | 01:30 PM
Mrmatt2009's Avatar
Mrmatt2009
I have been having the same problem too! and i was wondering about the silicone spray too, and i was thinking about trying it on the top weather stripping too to see if it would help my leaking top
Old Dec 14, 2010 | 01:44 PM
383vett's Avatar
383vett
Silicone spray works. Dielectric grease also works since it is silicone based (I think).
Old Dec 14, 2010 | 01:53 PM
MissileDoc's Avatar
MissileDoc
I just went through this with my daughter's car. Spray silicone on a rag and rub it on the seals. Works great.
Old Dec 14, 2010 | 01:57 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
If you do have a leaky top or window to A or B pillar seals the door carpet will get wet and freeze to the sill trim. Next time it rains hard, check your door carpet for wetness too. Not the best solution, but you may need some silicone based product applied in that area too.
I had to have a heat gun out last night to get the car open.
Old Dec 14, 2010 | 05:03 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
Yep
Old Dec 14, 2010 | 06:06 PM
NJ_Corvette_Kid's Avatar
NJ_Corvette_Kid
Kind of glad this was brought up as I noticed some freezing on the lower part of the door towards the front. I do have a leak at the top where the weatherstripping meets. At least I think thats where it comes from.
Thing is the stripping looks pretty good.
Anyways it drips a bit onto the seat from the top where the two pieces meet... and also onto the rug on the door carpet. Suggestions on what pieces to replace or to replace at all?
Where is the most common spot for the stripping to leak? And is it worth it to replace or will it leak soon after to some extent? I have a coupe not convertible.
Im trying to get everything perfect with the car or as close as possible.
Thanks!
To Freezing Door Seals
