What is the best setup?
Old Dec 14, 2010 | 03:17 PM
Joe Tagliarini's Avatar
Joe Tagliarini
Default What is the best setup?
Engine has about 500 miles and 12 dyno pulls made just over 600HP at the rear wheel w 24# boost.
Engine was just freshened up witt all new rings and bearings, all highest quality parts used.
Block is a 1 piece rear main seal block w brass frost plugs, billet splayed 4 bolt caps $1400 spent on machine work
Crank is Callies Dragon Slayer 3.75" Stroke
Rods are Probe I beam rods w ARP bolts
Pistons are Probe 4.060" bore HD Turbo spec w dished top for 9:1 compression
Rings are Speed Pro plasma moly
Bearings are Speed Pro Race Series HD Tri Metal
Cylinder heads are Pro Comp CNC Vortec aluminum with dual bolt pattern to accept stock TPI intake
All gaskets are Felpro with MLS head gaskets
The rocker arms are Comp Cams 1.6 ratio Pro Magnum roller
High Volume oil pump and pickup with Corvette baffled oil pan
ARP head bolts
I have three different camshaft setups
1 is the custom ground flat tappet hydraulic turbo cam which is new
2 is Comp Cams 292XFI 12-468-8 which is very agressive cam for the street with solid roller lifters set at .005 lash for high RPM with solid roller spec valve springs make alot of power w an agressive idle
3 is a mild turbo spec solid roller w solid roller springs and lifters
Setup 1 is $2700
Setup*2 is $2950
Setup 3 is $3050
What to one I should get to my 80mm turbo kit rear mount?
Old Dec 14, 2010 | 03:36 PM
engle1147's Avatar
engle1147
Sounds impressive......this is the C4 Tech section though.
