Temp Sensor
Old Apr 7, 2002 | 08:32 PM
Secondvet's Avatar
Secondvet
Default Temp Sensor
Need to replace temp sensor broken when installing camber brace, do i need to drain any coolant and if so how much. BTW camber brace in place and clearances good. Was pita but should be worth the effort. Thanks for any feedback. :yesnod:
Old Apr 7, 2002 | 08:55 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Temp Sensor (Secondvet)
All the coolant temp sensors on the L98 block go into the water jacket. This requires draining coolant down to that sensor.
