Driver door contacts hood when opening/closing door?
Is there any provision for adjustment there? About 1/4 of the way from the top of the driver's door, the leading edge contacts the trailing edge of the hood, at one point during opening or closing the door.
Loosen the hood pivot mounting bolts and pull the hood forward 1/8" and retighten.
I swapped out the driver's side hinge yesterday, there was a huge amount of slop in the actual pivot pin... of course, now I can't really get it aligned as well as I'd like, but the rubbing on the door has stopped.
