Lt1 high idle
Old Dec 19, 2010 | 06:49 PM
white_mike_parks's Avatar
white_mike_parks
Default Lt1 high idle
Just did the trick flow heads and cam kit andstarted for the first time and it idles around 25oo rpm. I adjusted the t body back and it didnt help im lost this is my first project car so dont really know what to do here any thing will help
Old Dec 19, 2010 | 07:04 PM
tblt44's Avatar
tblt44
When you get this figured out let us know how it runs ,I was thinking about it also.Is that the kit that claims 430 HP?
Old Dec 19, 2010 | 07:19 PM
white_mike_parks
I mean othe than the high idle it sounds like a beast!! But i also got rid of the cats and egr system and did intake bigger t body and have hooker headers and a corsa catback system but i definently put the final dyno numbers up for everyone
Old Dec 19, 2010 | 07:46 PM
tblt44's Avatar
tblt44
Now that you posted what else you did maybe it will be easier for everyone to help figure it out.
Could it have something to do with the EGR delete ???
Do you have everything pluged it IAC valve ,ect
Old Dec 19, 2010 | 07:51 PM
white_mike_parks
The only thing not plugged in is the mass air flow sensor but when its plugged in i kills the motor so i know thats a prblem and have one ordered but other than that and the egr delete everything is hooked up
Old Dec 19, 2010 | 07:59 PM
tblt44's Avatar
tblt44
I was just reading up on a article on the trickflow kit and it says it requires a tune.I would think it should Idle normal.The ecm should idle it down after a few seconds
Old Dec 19, 2010 | 08:07 PM
white_mike_parks
I read that too but i want to have everything running good before i take it to get tunned you know
To Lt1 high idle
