Help me out please
Old Dec 26, 2010 | 07:03 PM
gsff19's Avatar
gsff19
Cruising
Default Help me out please
I am looking at re building or upgrading my cross fire injection system. I am not very corvette smart, sadly.
I was wonderig if anyone had any suggestions or good web sites to purchase these kits from.
Ive looked some and since Im not really sure what to get its a little confusing.
I have a 1984 corvette all stock with 76,000 miles on it. Id like more power, smoother running and im sure being as old as it is, she could use a rebuild.
Thanks.
Greg
Old Dec 26, 2010 | 07:34 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
1984 Corvette Help 1
1984 Corvette Help 2
Originally Posted by Pete K
As a newer member, you may not be aware that this is discussed very often. After years and years of archiving data, many do not wish to answer the same questions over and over.
I have not done the swap, so I cannot offer 1st hand advice.
I would recommend using the search feature to look back at all of the carb swaps done in a c4.
Good luck.
You were thinking about this last year. I guess we will see the same trend for 2011. See ya'
Old Dec 26, 2010 | 07:37 PM
C409's Avatar
C409
......... With only 76,000 miles, its just breaking in ............
Old Dec 26, 2010 | 07:51 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Originally Posted by gsff19
Here is my issue, I have a stock 1984 corvette with the L89, Im looking to put in a crate motor most likely a 350 with a carb/air cleaner. I need to know if anyone has done that and what I need to look out for.
Do I need to change any of my cooling components?
is there any hood clearance issues?
whats a good motor to use?
What extra will I have to purchase with the motor?
Really Nobody has any advice.........
Thanks.
Greg
You should go carb for sure.
Old Dec 26, 2010 | 07:53 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
^I agree. Run the wee out of it.
If you're bent on the crate motor to replace a low, 76k mile motor, you need to either port the stock intake, or try to buy the Renegade, if you can get one.
Old Dec 26, 2010 | 11:32 PM
PLRX's Avatar
PLRX
2017 C4 of Year
To Help me out please
