L98 engine advice
Recently purchased an 88 corvette with a bad rod bearing. Pan and rod caps came in a box with the car.
I already have borrowed an engine hoist and am ready to remove the engine soon.
Local engine/balance shop has quoted me 2500 for a newly machined and balance long block. 3500 would be my outside budget for the mechanical portion of the project. I am aware that making power costs money.
Problem: 240 rated hp in a rebuilt corvette motor seems so under-rated. I am almost finished with an overhaul of a comperable (non-smog) motor of aprox. cid w/ an output in the 430 hp range.
What can be done within my budget to make this corvette run proudly. Remember my budget is capped for now around 3500. So I am not expecting a mid to low 11 second car. Very low 13's or maybe better is more realistic imo.
This car has to pass smog as I live in central CA.
I am being advised by a local corvette guru to leave it stock. He is telling me it will never run correctly if its modified and that those with fast corvettes like mine are only driving 1/4 mile at a time.
Please advise....I am all ears.
Thank you in advance for any tech support.
If there are not too many miles, you might consider just pulling the crank and have it turned and go with new bearings. Then a cam like the Lingenfelter 74211 (passes SMOG) a good set of heads and you can be in the mid to low 13's. If you do most of the work yourself except machine work, you can keep the costs down.
I would like to benefit from a tried and proven design that is within my budget. I am capable of building the internals of this engine myself. This could free up a few dollars for a better intake set up and or exhaust.
BTW..what specific intake parts are needed to let these motors breath well and still pass smog? I am new to this efi / smog compliant hp improvements.
I would like more cam options that are for sure smog freindly if possible.
I will research the cam spec for the Lingenfelter 74211
Thanks again...all info shared is greatly appreciated.
Every year the Ca. govt. is dropping the max. allowable limits on smog testing to get these old cars off the road. Once you have it running in stock form you may like it.
There was alot of good info regarding ca. lowering limits in my failed smog thread.
Mike
But ...are you keeping the car ? if you are , you can always swap cam,heads,intake in th future , now that the engine is out and removed i woulnd't make the mistake i made.
I would stroke it to 383, i have no idea how much more is involved but if you can
get forged pistons and rods,plus the stroker crank.
Im not sure if this will fit the budget but back in 2008 i rebuilt my engine on a budget (ZZ4 Cam and springs) and that was all, 3 years later i wish i had a 383.
Especially if built right and a 150 HP + shot of nitrous oxide is used at launch and you can get the power to the ground on launch.
A friend of mine had a 1987 Chevy Monte Carlo. Built up a 383 with old 292 casting double hump heads. Sprayed nitrous into it.
Used a 700 R4 trans. Installed a 12 bolt rear from 1970 Chevelle with 4.10 gears. Ran Mickey Thompson Tires out back.
Upon launch even on street, he would lift the front wheels off the ground easily 6 inches, sometimes 2 feet. LOL
And was gone in a hurry..........
In my 1970 Pontiac Ram Air 4 Trans Am 4- speed ( No Nitrous), He would get me out of the hole - launch.
I would catch up at the end of 3rd gear(ready to make my 7,000RPM shift),
At the 3- 4 shift in my car, I would over take him around 100 MPH.
If I screwed up shifting ever, he would be gone. LOL
That 383 was fast lol.
He quite never got over getting beat by me in my T/A.
As he never got beat.
He would show up nearly every night wanting to race wherever I was locally.
Or launch his car in front of myself or others wherever we were.
