Found Problem (*WITH PIC*) - Now how do I fix it?
Old Dec 28, 2010 | 03:22 PM
Aopsahl7's Avatar
Aopsahl7
Default Found Problem (*WITH PIC*) - Now how do I fix it?
Hey guys,
I posted up a few days ago about my rear tires basically steering the car under acceleration and down shifts. I got it up on jack stands today and the problem was pretty obvious. Looks like a broken tie rod.
Here is the picture of it.
Now my question is do I need to replace both sides and that middle piece that links them above the diff? Or Can I just replace the end? Helppp!!!
Any tips are appreciated too I am new at all this.
Old Dec 28, 2010 | 03:49 PM
c4cruiser's Avatar
c4cruiser
I would go ahead and replace the entire assembly. You didn't say how many miles are on the car, but it would be worth getting all new components. Definitely replace both tie rods ends at the same time.
IF the rubber components look dried out or cracked, consider replacing as many pieces as you can do. With the new tie rod ends, you should get an alignment.
Old Dec 28, 2010 | 05:17 PM
rinosaur's Avatar
rinosaur
it looks like you only *need* to replace the outer, just take some grips and unthread the broken part out of the inner part. but like others say, it could only be a matter of time before the other one goes.
Old Dec 28, 2010 | 05:39 PM
ch@0s's Avatar
ch@0s
Ouch you drove it like that?
Replace both tie rod ends.
Old Dec 28, 2010 | 05:49 PM
jhammons01's Avatar
jhammons01
If I remember, I told you not to panic...it's not really anything to stress over...and look...a simple swap of old for new and all is well again
Old Dec 28, 2010 | 05:52 PM
Aopsahl7's Avatar
Aopsahl7
Just ordered the replacement parts for the whole tie rod set up both sides in the back. Hopefully I will get them on this weekend.
Yes I drove it like that home. I limped it and thought I was gonna lose it. Not a good idea.
Thanks again fellas!
Old Dec 28, 2010 | 08:24 PM
383vett's Avatar
383vett
Good decision changing both sides. Stop driving off curbs.
Old Dec 28, 2010 | 09:24 PM
fc_soldier's Avatar
fc_soldier
I have a spare set that Ill sell you Im in VA.
Old Dec 28, 2010 | 10:49 PM
Samhain's Avatar
Samhain
Also, get an alignment after you replace everything.
Old Dec 29, 2010 | 10:03 AM
larry93lt1's Avatar
larry93lt1
From: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
Just takes a few $$$'s and a busted knuckle or two. Make sure you use those jackstands !
To Found Problem (*WITH PIC*) - Now how do I fix it?
