Service ASR
Old Dec 28, 2010 | 01:14 PM
xzo124's Avatar
xzo124
Default Service ASR
Had the light on dash come on last night "service asr" on 93 convertible . What does it require to fix problem . TIA...xzo
Old Dec 28, 2010 | 01:39 PM
pcolt94's Avatar
pcolt94
I would pull the codes and see if there are any. If you have one it may give you some direction.
Do you know how to pull the codes the codes.
I would also clear the codes and see if it returned if there are any.
Does the ASR still work?
Old Dec 28, 2010 | 04:11 PM
xzo124's Avatar
xzo124
No , I do not know how to pull the codes . And yes the ASR still works.....xzo
Old Dec 28, 2010 | 05:03 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
stealership
Old Dec 28, 2010 | 05:17 PM
redvetttes's Avatar
redvetttes
What is a ASR?
Old Dec 28, 2010 | 06:13 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Originally Posted by redvetttes
What is a ASR?
ASR: Acceleration Slip Regulation
More commonly known as "Traction Control"
It was introduced for the '92 model year.
The Corvette ASR (Acceleration Slip Regulation) created by Bosch was introduced. Standard equipment on all Corvettes, it worked by retarding the engine spark, closing the throttle and brake intervention. The throttle cable relax feature was interesting. It communicated to the driver that the system was "taking over" by giving him/her a gentle push back on the gas pedal. It was designed with the performance oriented driver in mind and could be switched off.
Old Dec 28, 2010 | 06:56 PM
turbotim23's Avatar
turbotim23
I'd be interested in knowing how to reset the asr on a 93 also. Will unhooking the battery turn the light off? Thanks Tim
Old Dec 28, 2010 | 07:41 PM
c4cruiser's Avatar
c4cruiser
If there is a code (or codes) set, the problem will have to be fixed. Disconnecting the battery will not turn the light off. After 50 ignition cycles, the light will go off as long as no recurring faults are detected.
The FSM has over 130 pages relating to diagnosis and repair of the ABS/ASR system. ABS is a part of the ASR and they work together. In order to properly diagnose the Service ASR light, codes will have to be pulled using a GM Tech 1 scan tool or similar tool. There are different testing procedures depending if there are codes or no codes.
Old Dec 28, 2010 | 09:49 PM
pcolt94's Avatar
pcolt94
And in addition
The ASR codes is controlled by the EBTCM or brake computer. You cannot reset the codes by removing the battery cable like the CCM and ECM. It can be done by the on board diagnosis also. That module is # 9.0 and you can go to module 9.7 to delete the codes. However find out what they are first.
But before you can jump in you need to learn how to pull the codes and use the on board diagnoists which work quite well. Here are a few links that are all similar to get you started. It is also best to get a FSM for your year car if you plan to get involved in repair of it.
http://forums.corvetteforum.com/c4-t...-retrieve.html
http://www.corvettebuyers.com/c4vettes/codes.htm
http://www.corvette-guru.com/uploads...CMCodePull.pdf
Old Dec 29, 2010 | 08:21 AM
digitalray's Avatar
digitalray
had the exact same problem on my 93 conv lt1 5.7l yesterday evening.
i drove away from the gas station and heard the asr coming on, used the cruise control after that for a short time.
after about 5 mins later the "service asr" came on for the first time ever.
i tried pushing the asr on/off button with pause between on/off but it didn't turn the "service asr" light off.
i turned off the ignition at the red traffic lights and back on, and the "service asr" lights came on with all other lights, but turned off when i started the engine. so i guess there "might" be a problem, but not that much of a problem to worry about as it didn't come on again ?
in a post before this i read that the "service asr" light should stay on as long as an error code about abs/asr is stored, so i guess there is no error code stored because it's off after starting the engine a 2nd time ?
i'll try to recover error codes later this day. i read everywhere it's not needed to service the asr or open it anyway. but there is a label on the asr box telling me to look in the manual for throttle cable adjustment. so i guess it is needed to adjust this cable from time to time ?
ray
Old Dec 29, 2010 | 05:26 PM
turbotim23's Avatar
turbotim23
Well in my case I know why the asr light is on. When I was working on the c5 front brake upgrade, I had to move the car.Didn't have anybody to help me so I just started it up and drove it with no brakes to where I wanted it. Light has been on ever since. Kind of my own fault. Thanks Tim
Old Jan 1, 2011 | 12:12 AM
digitalray's Avatar
digitalray
something else i realized is, that the engine idles at about 1100 most of the time, the whole last year it went down to about 600-800 when idling.
could this be because of the extreme low temperatures (about -3 to -15 °C here) ?
or could this be related to the "service asr" light coming up one time (not again after).
sometimes the engine seems to give some throttle when idling, seems like it does that because the engine would stop otherwise or idle way too low.
it didn't do that last year (but i didnt really drive in winter back then).
is that normal behaviour ?
it's a 93 LT1 5.7l Manual Transmission Engine
Old Jan 1, 2011 | 11:03 AM
Guitarguy's Avatar
Guitarguy
check your brake fluid level.
Old Jan 1, 2011 | 11:21 AM
digitalray's Avatar
digitalray
thanks, i will try changing it. does this really affect the idling and in which way or does it just affect the break pedal and eventually abs ?
Old Jan 7, 2011 | 07:30 AM
digitalray's Avatar
digitalray
checked it. it's ok. filled up to the line and was completely replaced 2 years ago, so it should be fine.
i made a checklist with symptoms i got:
- Service ASR light is coming on once a week after driving for about 10 or 15 minutes while driving straight and constantly with no special driving actions involved.
- when i start the engine, there is a light humming sound from the front, like it is doing a check, but it doesn't go off after 20 seconds sometimes like normal.
- got problems with idling speed, goes up to 1200 and stays there sometimes. 2 times so far the engine
suddenly dropped idling and is about to go off completely but then it gives throttle automatically and keeps running, but with idle speed up to 1200 again. never had that before, the engine is fine, had it inspected by 2 mechanics and 1 engine builder, all said it's in very good shape for a 93 LT-1. oil is changed twice a year with mobil1 10w40.
- the PSR antitheft does only work once in a while anymore.
- sometimes "service engine soon" comes on together with "service asr". when i press the asr off button, the "service engine soon" light goes off again while "service asr" stays. when i turn the engine off and on again, lights are off again and asr still works then.
- about 2 mins after the "service asr" light comes on, i get a 5 x bing sound while driving contantly like when you get in your car and haven't got your seatbelt on or stop your car and haven't turned the lights off. no sys error or anything other while or after the sound.
- didn't get a SYS ERROR displayed so far.
Old Jan 7, 2011 | 08:37 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Good news is you can check the codes without going to the dealer.
Do a search - IIRC you ground two connections in the ALDL connector and they show up on the spedometer. If you have a FSM the procedure is there. I used to have a link to a pdf that duplicated it. I have a set of grounding plugs from Gordon Killebrew that I use.
I've got a similar problem, but since I hate the way it works and my car is turning into a road race car I'll be removing it.
Old Jan 11, 2011 | 01:45 PM
xzo124's Avatar
xzo124
added brake fluid , no more light on dash. I replaced brake pads in front earlier in 2010 . Tells me I need to check pads in rear pretty soon , brake fluid low from caliper piston extented. Thanks Guitarguy...xzo
To Service ASR
