The topic says it all,I need help guys
here's what i've done...I changed the opti this weekend as well as the ign. mod. ,coil and batt within the last month.Here 's what it's doing she starts fine idles fine then when i take the rpm's up above 3500-4000 she immed. dies and will not start back up till she cools for a couple hours.no codes on the computer!!before i changed the opti it was 16 code....please help love the car but need transportation quick!
Thanx Tony
I first thought that the coil was defective. But if you replaced it with a new one, can't be that. You did not say if you have recently replaced the fuel filter. It could be that. Only two things could cause that problem described, lack of spark or lack of fuel. It seems like you took care of the spark part with the replacement of all of those parts. So you need to see if there is fuel pressure after the car dies and will not restart. I would also check to verify that spark is present at that time. This will verify a few things and atleast point us in the right direction. Since no codes are present, we can't use that for diagnosing the problem. Let us know what you find out and we can go from there.
will do thanx again guys ..now that it is mentioned i do have a noise coming from the drivers side cat. it kinda rattles could that really cause that magnitude of a problem? The fuel filter was changed about 10k ago so what I'll be looking for is simply spark and ending fuel pressure? I'll let you know!
Thanx again !
Tony
