Grease
Old Dec 30, 2010 | 01:36 PM
Ant1981's Avatar
Ant1981
Default Grease
For my grease gun, I need to get a cartridge of grease for when I change my UJ's. Will any automotive high melting point bearing grease do?
Old Dec 30, 2010 | 01:42 PM
Baldfart's Avatar
Baldfart
Old Dec 30, 2010 | 01:43 PM
Ant1981's Avatar
Ant1981
Originally Posted by Baldfart
Thanks, that's really helpful.
Old Dec 30, 2010 | 07:29 PM
87 vette 81 big girl's Avatar
Usually the answer is yes.
Just make sure it has a high melting point.
Mobil Grease, the Blue stuff is great.
Kendall Blue also great if you are able to find it.
Or Royal Purple synthetic grease.
All available in Cartridges for your Grease Gun.
Use a quality grease and the U-joints and chassis parts on your Vette will live a long life.
BR
Old Dec 30, 2010 | 07:45 PM
Ant1981's Avatar
Ant1981
BR
What grease points are on the chassis parts?
Old Dec 30, 2010 | 08:05 PM
tblt44's Avatar
tblt44
I use green grease
http://www.greengrease.net/newstickler.html
http://shop.advanceautoparts.com/web...%7CGRP2035____
Old Dec 30, 2010 | 08:28 PM
I have to ask,...........
You never have greased any of the upper and lower ball joints, Front outer tie rods, and outer rear toe - tie rods on your Corvette ?
If not, you should grease them at every oil change.
BR
Old Dec 30, 2010 | 08:39 PM
samsonb's Avatar
samsonb
I use the Valvoline Synpower synthetic grease. It doesn't leak out the zerk fitting like other greases can.
I don't grease ujoints since I use sealed ujoints.
Old Dec 30, 2010 | 09:25 PM
Road Agent's Avatar
Road Agent
Old Dec 31, 2010 | 05:20 AM
Ant1981's Avatar
Ant1981
BR
Oh I see, I don't call those chassis parts, I just call them by the names you outlined. Though I don't recall seeing a grease nipple on any of those. I'll take a closer look.
Old Dec 31, 2010 | 05:50 AM
cv67's Avatar
cv67
St. Jude Donor '05
Good stuff!
Too bad when I put my front end together all I could find was waterproof trailer bearing grease
Hey it works great.
Old Dec 31, 2010 | 06:26 AM
Good stuff!
Hey it works great.
Water Proof Trailer Bearing Grease will work good too.
Its Super Tacky Grease/ Sticky Stuff !
Also Hard to get the stuff off of your hands and tools ! Lol
Old Dec 31, 2010 | 06:41 AM
cv67's Avatar
cv67
St. Jude Donor '05
You referring to Ujoints without the zerk?
Old Dec 31, 2010 | 06:59 AM
samsonb's Avatar
samsonb
Yes.
To Grease
