Keys made...
Old Dec 30, 2010 | 05:01 PM
overdrawn's Avatar
overdrawn
Default Keys made...
I need an extra key made, I called a mobil locksmith, he wanted 85.00 I told him I didn't need it that bad...any ideas as to where I could go?
Old Dec 30, 2010 | 05:16 PM
gkrynick22's Avatar
gkrynick22
So you need a copy of a key made? Is it just a door key or the ignition? A door key you could probably just go to you local hardware store. The ignition key you could try a Chevy dealer. When I had my 1994 Trans Am, I had a Ignition key copied at a local dealer. They only charged me around $15 and I believe it was a VATTS key.
Old Dec 30, 2010 | 05:17 PM
pcolt94's Avatar
pcolt94
If you have your own ignition key, and you go to a locksmith and walk in, a key should be $25 or less. Even at a dealership it is not $85.
If you don’t have an original key, that is a different story and cost will be different.
Old Dec 30, 2010 | 05:19 PM
robw2p's Avatar
robw2p
I recently had an ignition and door key made at the dealership for $24.
Old Dec 30, 2010 | 05:22 PM
overdrawn's Avatar
overdrawn
Yes, just an extra copy of ignition key, thanks I'll try chevy dealer.
Old Dec 30, 2010 | 05:28 PM
gkrynick22's Avatar
gkrynick22
Bring the Title or Registration to your car with you. I believe in for a 1992 they can cut the key using info from the Vin#. They will just want proof you own the car before they will cut a key for you .
Old Dec 30, 2010 | 05:33 PM
redvetttes's Avatar
redvetttes
Does a 86 have the VATS key ?
Baldfart's Avatar
Baldfart
Old Dec 30, 2010 | 05:53 PM
Tom 35th anniversary's Avatar
I ordered mine off of ebay, new and uncut for $11 a piece. Had em cut at local hardware for a couple of bucks. On an 88.
Old Dec 30, 2010 | 05:57 PM
gkrynick22's Avatar
gkrynick22
I know 85 doesn't, not sure about 86. If your key looks like this it does.
Old Dec 30, 2010 | 05:58 PM
hooked073's Avatar
hooked073
If you called a mobil locksmith they were probley adding $50.00 for the service call and drive time. If you just need the copy any dealer can do it. I bet a few hardware stores can stiil cut it. should be less then $20.00
Old Dec 30, 2010 | 06:13 PM
JackDidley's Avatar
JackDidley
86 does have VATS.
Old Dec 30, 2010 | 07:47 PM
vetteson's Avatar
vetteson
If it has vats you can measure the resistance of the chip and get the key chip code. I ordered a blank key for my 94 Trans Am from ebay and just told them the type of resistor that was in it. They sent me a blank with that chip in it and I took it to a hardware store and had the key cut.
Old Dec 30, 2010 | 07:52 PM
vetteson's Avatar
vetteson
http://cgi.ebay.com/ebaymotors/1985-...Q5fAccessories
Thats who I ordered mine from
Old Dec 30, 2010 | 07:56 PM
LT4 F45's Avatar
LT4 F45
Originally Posted by JackDidley
86 does have VATS.
86 And up
Old Dec 30, 2010 | 08:00 PM
rinosaur's Avatar
rinosaur
I just bought 2 blanks on ebay for my 94 for $12.50 shipped. Ace hardware cut one of mine for $1 . Thats $7.25 per fully functional ignition key.
Old Dec 30, 2010 | 09:35 PM
xole's Avatar
xole
You would be suprised how many places CAN deal with duplicating the keys with the resistors.
I measured mine, purchased blanks from ebay and then carried them to my local ACE hardware to have cut....only to find out they had all the different blanks there. They even checked the resistors to make sure I had gotten the correct blanks.
-D
Old Dec 30, 2010 | 09:47 PM
dogfish246's Avatar
dogfish246
-D
I measured my resistor with my ohms meter and got blanks for $2 each and went to home depot and the guy wouldnt cut them... So I walked out and went to NAPA and they said they really didnt want to cut them and I told them that they wouldnt be responsible if they broke the blanks and they did both of them for under $10...
So for under $15 I got my keys made!
To Keys made...
