I have a 1995 lt-1 corvette( 80,000 mi.) and i am going to add these items friday:
1.TPIS long tubes, y-pipe, No cat, B&B tri-flo cat back
2. New msd wires and plugs
3. Cut air lid K&N filter
4.52mm throttle body
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: How much horsepower will this add? (Kehrer923)
First DON'T use the Y-pipe. run it back off your car-back it will work that way.
The headers and 52mm tb will in most cases slow you down unless you have the heads and cam to go with it.
The wires will give you nothing if your wire are good now.
The open and K&N are worth alittle.
Re: How much horsepower will this add? (mackeyred96)
...The headers and 52mm tb will in most cases slow you down unless you have the heads and cam to go with it....
I agree the 52mm TB won't do a thing, but the I expect the long tube headers will be good for 15-20 RWHP. That's what most magazines seem to report and it coincides with some of the forum member's results (Nathan for example).
Wires don't give you a thing unless your existing ones are bad. Y pipe would be worse because it forces you to a single pipe (instead of duals). Have the shop weld up something to connect the headers to the catback.
