Shift light help
Old Jan 2, 2011 | 05:58 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default Shift light help
I just installed a shift light and it doesnt work on any setting but 3k cant figure out why it wont work on the higher rpm settings
Old Jan 2, 2011 | 06:03 PM
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
What type of shift light do you have?
Old Jan 2, 2011 | 06:16 PM
kimmer's Avatar
kimmer
A Glow shift, inexpensive but I thought it would do the job. Pretty simple install, tach wire, key on power and ground. Could a bad ground caues this?
Old Jan 2, 2011 | 06:56 PM
383vett's Avatar
383vett
Is the motor at 3K when the light goes on? Are you taking your tach signal off the brown tach wire leaving the disributor?
Old Jan 2, 2011 | 07:06 PM
kimmer's Avatar
kimmer
Yes at 3k on my tach the light goes on, my signal is the white tach wire at the firewall inside the black cover.
Old Jan 2, 2011 | 07:10 PM
383vett's Avatar
383vett
Is that the one that goes to the tach filter?
Old Jan 2, 2011 | 07:12 PM
kimmer's Avatar
kimmer
That is correct.
Old Jan 2, 2011 | 07:14 PM
383vett's Avatar
383vett
2 thoughts; take the signal from the other side of the tach filter. Hook up a conventional tach to this wire and see if the rpm's are correct. If you're getting a correct signal, then you shift lite is kaput.
Old Jan 2, 2011 | 07:17 PM
kimmer's Avatar
kimmer
Thanks, will check it out
To Shift light help
