Battery Tender
Old Jan 2, 2011 | 07:54 PM
blacker's Avatar
blacker
Default Battery Tender
I am wanting to connect a Battery Tender on my 89'. I am wondering if I should connect the positive and negative cables directly to the battery terminals or if I should connect the postive and ground the negative. If so, where is a good place to ground it?
Old Jan 2, 2011 | 08:47 PM
oldalaskaman's Avatar
oldalaskaman
disconnect the battery from the car and hook it direct to the posts. did a solar tender that way in alaska , worked great.
Old Jan 2, 2011 | 08:48 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Hook them directly to the battery terminal.
Old Jan 2, 2011 | 08:53 PM
AGENT 86's Avatar
AGENT 86
I wouldn't bother disconnecting the terminals, you loose all ECM memory and radio memory. Not a big deal, just my opinion.
Old Jan 2, 2011 | 09:31 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Old Jan 2, 2011 | 10:22 PM
cfi's Avatar
cfi
I've used a battery tender on my 89 for years hooked directly to the terminals with battery connected. absolutely no problems.
89 red coupe
Old Jan 2, 2011 | 10:28 PM
jfb's Avatar
jfb
The safe way to make charger connections to car batteries is to connect the positive clip to the battery post and the negative clip to a ground that is away from the battery. When disconnecting, remove the negative terminal first. This keeps sparks away from the battery which normally emits hydrogen and oxygen gas which is explosive. You should also make connections when the charger is unplugged from an outlet. Bare bolts or nuts usually are connected to ground, but you can use any bare metal parts like brackets that are fixed to the engine. You can also use the negative cable from the battery if it is of the braided wire type.
Old Jan 2, 2011 | 10:30 PM
1989TransAm's Avatar
1989TransAm
As with the above posts I have been using a battery tender on my car for years hooked directly to the battery with no problems.
Old Jan 3, 2011 | 12:55 AM
Mrs. glass car's Avatar
Mrs. glass car
I have 2 cars that are garaged and seldom driven, battery tenders hooked directly to the terminals on both of them for years. No problems.
Old Jan 3, 2011 | 08:11 AM
jfb's Avatar
jfb
YET! The danger occurs when making or breaking the contact with the battery post. A spark right at the battery can ignite the hydrogen/oxygen gas that all lead acid batteries generate, both during charge and discharge and it is explosive. Making and breaking connection away from the battery ensures no explosions. Never having a problem in the past is no guarantee that your unsafe practice will continue to be problem free. Sulfuric acid can destroy your eyesight.
A word to the wise should be sufficient.
Old Jan 3, 2011 | 09:08 AM
AGENT 86's Avatar
AGENT 86
Common sense says to plug in your charger after the connections are made. Wouldn't that eliminate any chance of a spark ?
Old Jan 3, 2011 | 10:53 AM
RUU's Avatar
RUU
It should as the only current draw would be to power the polarity indicator on the charger. Now boosting a car with jumper cables is a different story...
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
That and the fact that the pigtail connector is over a foot away from the battery. I run mine out between the hood & inner panel then close the hood. Common sense tells you to unplug the charger before disconnecting it too.
Old Jan 3, 2011 | 11:08 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Yup. Just hook it up directly to the terminals. No drama.
Old Jan 3, 2011 | 12:40 PM
Mrs. glass car
No current flow with the tender unplugged.
Old Jan 3, 2011 | 01:43 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Been using them form10 years with no problems.
Old Jan 3, 2011 | 03:37 PM
j-wireman's Avatar
j-wireman
Re: Sparks while connecting clips on a battery
You might be thinking of when you are using jumper cables. In that case, you most certainly should clamp the negative jumper away from the battery, onto a ground such as the alternator bracket.
I've had a Battery Tender Junior on my '90 for about 3 years now without a problem. I elected not to use the ring terminal adapter for concours reasons. I use the color-coded clips and I have never had a spark while connecting it. By the way, I got it on sale at PepBoys for $18+tax. One of my better investments.
To Battery Tender
Old Jan 3, 2011 | 04:02 PM
jon0108's Avatar
jon0108
directly to terminals
Old Jan 3, 2011 | 11:28 PM
SJW's Avatar
SJW
Here's how I connect mine:
No permanent wiring added to the car, no lifting the hood, no sparks near the battery (and yes, you should take that very seriously).
Live well,
SJW
Old Jan 3, 2011 | 11:52 PM
jfb's Avatar
jfb
Not true. Battery tenders usually have an electrolytic capacitor on their output circuit and when you connect the charger clips to the battery with the charger not plugged into the wall socket you still get a spark. My tender does. You are betting your eyesight, do you want to do that?
