engine vibration
Old Jan 9, 2011 | 10:33 PM
94vettelover2's Avatar
94vettelover2
Originally Posted by ndanl
ok, belt and tc are off, engine still vibrates like it is off balance, maybe the harmonic balancer is damaged, will order a new one hope to get it next month ...
do I need to order anything else besides the harmonic balancer like gaskets or something like that ?
could be a problem with the distribution timing, I dont know maybe a few degrees more or less, but I never touch it ?
thanks,
Dan
Check to verify that you installed the spark plug wire(s) correctly & didn't install or cross a spark plug wire(s).Did this problem exist before any of the work you did?Did removing belt change anything?Does the balancer wobble or shake while engine is running?
Old Jan 10, 2011 | 07:22 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
Originally Posted by Muffin
You don't need to do that. Remove the inspection cover, unbolt the TC , three bolts , slide the TC toward the rear. You should get something like 1/2-3/4 space between the TC and flex plate. The engine-trans mounting bolts are not touched.
Thanks. I think I could manage that test.
Old Jan 10, 2011 | 07:56 AM
87 vette 81 big girl's Avatar
You could also perform a Cylinder Balance Test using an old style SUN or Snap On Ignition Oscilloscope if either is available for you to use for testing.
A cylinder balance test done on these old Ignition system oscilloscopes will tell you if all 8 cylinders are contributing equally or not.
They perform a rpm drop test on a cylinder by cylinder or bank to bank basis, and measure the actual rpm drop(or + increase) when a chosen cylinder is dis activated.
If No Rpm drop is shown when that engine cylinder is shut down(ignition spark shut down in that cylinder) then you have isolated the problem cylinder. You can troubleshoot further into that cylinder.
Compression test next always good.
The cheap and dirty way of doing a cylinder balance test is a simple test light. The style with a tungsten filament light bulb inside.
Connect on end of the test light to ground, like the alternator bracket.
With the probed end of the test light, choose a spark plug wire and pierce though the insulation, if the engine speed drops, that cylinder is contributing correctly.
Using an old spark plug wire of at least 3 feet in length, you can replace it for the spark plug wire on your car for testing purposes only.
That way you dont ruin your good igintion wires intact.
Harmonic balancers do fail too. Usually you can see the outer inerta ring wobble around badly with the engine running if real bad.
BR
Old Jan 10, 2011 | 08:05 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
BR
Thanks Brian. Lot of good ideas there. Now that my 87 is purring along nicely (with its charging problem fixed) the 84 can get my full attention.
Old Jan 10, 2011 | 12:59 PM
ndanl's Avatar
ndanl
I removed each injectors plug and saw the rpm drops, I think I have all 8 cyl working right ?
will do a compression test in weekend, what values should I have ?
Old Jan 10, 2011 | 01:18 PM
LD85's Avatar
LD85
I spent a solid year and a bunch of money trying to find a vibration, my advise is to pull the tranny back as was suggested....
My vibration ended up being a that my new SCAT cast crankshaft twisted on my first hard drag launch,,,it was balanced perfectly by the engine shop and ran great until I launched,,, I looked at the spark, the distributor, the cylinders the timing, the damper , the valves, plug wires, I mean everything because "no one" thought that a crankshaft could be twisted,,, pulled it our and the crank was of 30 grams,,,so I threw the SCAT POS cast crank in the trash, literally, and bought a 4340 forged crank..
All I am saying is, rule out the tranny first, it will take some time, but I have been where you are now
Old Jan 10, 2011 | 06:09 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Larry, was the forged also SCAT? I was thinking of going with a forged SCAT.
Old Jan 10, 2011 | 09:02 PM
LD85's Avatar
LD85
Originally Posted by Ray Quayle
Larry, the the forged also SCAT? I was thinking of going with a forged SCAT.
Hi Ray, the problem cam was a SCAT 5140,,, I bought an Eagle 4340 with Eagle H-beam rods, and Wiseco forged pistons.
Be safe!
Old Jan 11, 2011 | 04:35 AM
ndanl's Avatar
ndanl
well I hope it s not the crankshaft. I dont have yet the budget to rebuild the engine
and the shipping to romania for every heavy part will cost me a lot of money
Old Jan 11, 2011 | 07:07 AM
LD85's Avatar
LD85
I am not inferring that it is a cam problem, but more likely, something with the tranny, or input shaft etc,,, just a guess, but if you take a couple of hours to rule out the tranny, then any other problem is mush less costly.
Old Jan 11, 2011 | 02:29 PM
bill mcdonald's Avatar
bill mcdonald
hi,
I own a 1991 corvette (L98), 66k on it, with automatic transmision, I recently managed to make the car run again, rebuild the transmision also changed the tc, changed plugs/wires, filters, oil, some sensors, everythings fine, no dtc errors, but the engine vibrates, I can fell the vibration in the steering wheel and when I acceletare the vibrations gets stronger, its like my mom washing machine, any advice please ?
thanks,
Dan
I think I would check these points over again.
Firing order.
Dist rotor in place and tight? Cap on good? Set the timing? At idle does it even sound right? If not can you turn the dist by hand and get the engine to smooth out?
Then I would check the harmonic balancer and then I would pull the TQ converter back.
I know what an out of balance engine feels like. I also know what firing order out of whack is like. they are different, and you can hear it in the exhaust. Out if balance engine will just get worse with RPM's. Screwed up firing order can be driven, but it has no ***** and just feels like something is very wrong and sounds like hell.
