Maf 89 c4
Old Jan 3, 2011 | 10:16 PM
midnightrdr's Avatar
midnightrdr
Cruising
Default Maf 89 c4
I changed out the MAF Sensor due to a code 34. I also have change the relays and believe I may have crossed the connections. I still have the service engine as soon as it starts. Is there any possible damages to relays, maf or ecm if the connections are crossed. The lighter wire is to the outside of the firewall and have found it in a display showing it to the inside.
Old Jan 3, 2011 | 10:25 PM
C409's Avatar
C409
..... You need a factory service manual ... it pays for itself over and over ..........
Old Jan 4, 2011 | 07:32 AM
WW7's Avatar
WW7
Both relays are the same so it doesn't matter if you cross them. This is actually how I tested mine to see if the power relay was bad..Something else is wrong,if you get a FSM it tells you how to test the system.Could be a bad wire or dirty connection..WW
To Maf 89 c4
