Heim joint rear toe links
Old Mar 4, 2011 | 02:23 PM
marcello7x's Avatar
marcello7x
what do you guys think of using these vs tie rods? http://www.speedwaymotors.com/Adjust...055#tabcontent
Old Mar 4, 2011 | 02:33 PM
bill mcdonald's Avatar
bill mcdonald
That one is a little different then a bump steer kit for our cars.
That one has bolts to move the heim location, the bump steer kit has spacers.
I put the bump steer kit on mine. Will set it up correctly when I get to rebuilding the front end. Didn't notce any difference right after install.
Old Mar 4, 2011 | 04:03 PM
Crepitus's Avatar
Crepitus
Old Mar 5, 2011 | 03:41 AM
ddahlgren's Avatar
ddahlgren
Where did you guys get your swedged rod? also where are you getting your heims? Anymore info would be great.
I bought the sweged tubes from afco and the heim joints from a friend that owns a chassis shop in Deleware that is an FK dealer. there are a bunch of different grades of FK rod ends he soldmethe super duty pieces along with the seals it stuff. I am sure there are plenty of good vendors for these. Stock car products and speedway motors comes to mind off the top of my head.
Dave
Old Mar 7, 2011 | 10:59 AM
87L98Z52's Avatar
87L98Z52
Can anyone give the length the rods need to be for trailing arms,camber rods,etc?
And is 3/4" your talking about the threaded diameter in the rod ends or hole in the heim joints?
Old Mar 7, 2011 | 12:08 PM
ddahlgren's Avatar
ddahlgren
15 camber
7 5/8 and 9 for dog bones
3/4 heim joints both threads and bore
