Intake porting
Old Jan 4, 2011 | 04:37 PM
1986-z51's Avatar
1986-z51
Default Intake porting
Well finally got around to putting in my camshaft last weekend,Got the intake off an got a good look at it. There is quite a bit of porting you can due to this intake,a very pore casting. I thought the intake restriction would be in the runners or upper plentum. After looking at it all I would say its the lower intake that is restrictive.So i am going to due a port an gasket match job on the lower. It has to help. 1986 cp.
Old Jan 4, 2011 | 04:39 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Great ! Send us some pics as you progress AND let us know if you realize a power increase with your porting efforts.
Old Jan 4, 2011 | 05:46 PM
HlhnEast's Avatar
HlhnEast
Be extremely careful with your intake as some of the walls are thinner than you think. This topic has been done many many times. Search out and read a lot before you start and see where folks have screwed up. Gasket matching isnt too risky but when you start into the walls you may run into trouble. The crappy molding on the inside is on the other side as well so you wont know its too thin until its too late. Have a buddy who does aluminum welding standing by!
http://forums.corvetteforum.com/c4-t...or-torque.html
http://forums.corvetteforum.com/c4-t...ke-plenum.html
http://forums.corvetteforum.com/c4-t...-manifold.html
http://forums.corvetteforum.com/c4-t...ng-intake.html
Just for a few. You can also go to thirdgen.org I think for lots more.
Good Luck!!
Old Jan 4, 2011 | 08:12 PM
cv67's Avatar
cv67
St. Jude Donor '05
Stock runners should be tossed in the trash or reuse them til you can upgrade they are a hindrance also, find yourself some used Accels or maybe some SLPs.
Or just do your portmatch put it back together and call it a day
Get yourself some dyekem and a scribe
Aftermarket pieces can be ported just not quite as much but they are already worlds better than the stock piece, siamesing the dividing wall down a few inches helps, too.
The base can be fuilly ported there is plenty of material that can be removed but youll need to go ALL the way through to make it really effective , it will take you quite some time.
Old Jan 4, 2011 | 11:04 PM
1989TransAm's Avatar
1989TransAm
There is work that can be done at the entrance area on the stock runners. It is not exactly a smooth transition from the casting portion to the runner tube itself. Best bet is aftermarket runners as said above.
Some of the plenums I have seen need work where the runners bolt on. Not exactly a smooth entrance to the runners. Should be a nice bellmouth shape. Also make sure the runners have at least the same if not larger opening at the plenum. You don't want a ledge in that area.
Again depending on your goals maybe an aftermarket base and runners would work better for you.
Old Jan 5, 2011 | 11:16 AM
engle1147's Avatar
engle1147
You can do lots of stuff (porting/grinding) to the top end of a TPI. Here is some of my ported L98 stuff:
Modified '89 plenum:
Modified SLP runners:
Plenum to runner transition:
Ported aftermarket intake:
Old Jan 5, 2011 | 12:20 PM
GKK's Avatar
GKK
Beautiful, work engle1147!!!
Old Jan 5, 2011 | 12:29 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Wow...That may be the cleanest plenum porting I've ever seen!
Old Mar 8, 2011 | 10:59 AM
Crowhater's Avatar
Crowhater
I just finished doing this job two weeks ago. I hammered those 1.5" steel ***** through my runners to stretch them out. Everything was gasket matched and opened up. I them closed off all of the Exhaust passages and plated off the EGR. When I was all done grinding I took it to S&S and had Allen tumble all of it for several hours. It all came out polished up like a new penny, I am talking slick as chrome. You could feel a diffrence for sure, it was not like hitting a 100 shot of N2O but you could tell a diffrence.
Old Mar 8, 2011 | 11:04 AM
1986-z51's Avatar
1986-z51
I could tell a big difference. I did add a 260 comp cam too.now i shift at 4800.Before it was 4300.
Old Mar 8, 2011 | 01:31 PM
GREGGPENN's Avatar
GREGGPENN
It's' definitely worth it. For my 383, my goal was to convert a set of SLPs to near superram configuration. By removing most of the divider and concentrating on the short-side radius, I think you can see how the effective runner tube gets very near superram length.
A 5200-5300 shift point is about right with this setup (probably higher with a 350).
Old Mar 10, 2011 | 11:20 PM
cv67's Avatar
cv67
St. Jude Donor '05
Below are a few pics of my work.
Boy those runners and base look familiar. What no plenum pic ?
http://forums.corvetteforum.com/c4-t...-far-pics.html
Last pic is his, different base.
engle, your work looks very nice.
Old Mar 10, 2011 | 11:35 PM
tpi 421 vette's Avatar
tpi 421 vette
[QUOTE=3859c1;1576994305]Awesome work! Below are a few pics of my work.
Someone mentioned the stock base being thin. In my opinion it's not as thin as it seems. I have ported quite a few stock GM TPI bases and there is plenty of material to be removed to make for major improvements! I just got done porting one for use with AFR 190cc L98 heads and I must say it's a monster!!! It's as good as any aftermarket TPI base, if not better. I will have pics of it soon.
Who ported those? You or Ron (Cuisineartvette)?
Old Mar 12, 2011 | 06:41 AM
mseven's Avatar
mseven
looks like ron's work to me..........
Old Mar 12, 2011 | 06:59 AM
navy_vette's Avatar
navy_vette
One could be extremely lazy and have someone else do it.
http://www.corvetteplenum.com/
Send them yours, and they send you one back, as far as i know.
If your not confident, something like this might be an option. I really don't know about this site, so I'm not advertising. I've never bought anything from them, but I've heard of them. Do research before you buy.
Old Mar 13, 2011 | 08:55 PM
T. Wayne Nelson's Avatar
T. Wayne Nelson
Jim, show the photos of your miniram....
Old Mar 17, 2011 | 11:13 PM
lgaff's Avatar
lgaff
2022 Corvette of the Year Winner -- Modified
2021 C4 of the Year - Modified Winner
Be glad you don't have to siamese 16 runners on IHs and the plenum
To Intake porting
Old Mar 17, 2011 | 11:23 PM
Dr.Huxtable's Avatar
Dr.Huxtable
+1!! i need to port my miniram when i do my motor swap. Here's some photos of some porting work i did on my previous car. Subaru Wrx, time to try my hands at a mini ram
Old Mar 18, 2011 | 01:55 AM
tpi 421 vette
Here's my miniram after Tony Mamo from AFR got done with it. It flows 410cfm.
It's been renamed a MamoRam
Old Mar 18, 2011 | 02:09 AM
cv67's Avatar
cv67
St. Jude Donor '05
Wow.
Fwiw the last pic Im unfamiliar with, not mine.
Never mind they were edited and deleted.
