Anyone out there have info on how to change the driver's side front running light? Looks like I have to go in from the top? are there any secrets to accessing this thing,, ( I know not to touch the halogen bulb etc)??
On my 1990 Convertible you go in from behind the bumper cover. You should be able to see the connector when you open the hood. Twist it out counter-clockwise and it will have a sleeve that comes out with it. Change the bulb and and replace everything opposite the way you removed it.
Smaller hands will work best as you will experience some bleeding when you squeeze your hands into that area where the blub comes out.
Also, since you're in Indy, perhaps you may want to look into the Great Lakes event section. There is a trip plannned to the Lingenfelter facilities on June 1st.
