Taurus 2-speed Fan Install
Old Jan 9, 2011 | 09:36 AM
C409's Avatar
C409
Default Taurus 2-speed Fan Install
... Thanks to a recent post , I decided to investigate the Taurus two speed fan upgrade on my '87 vette .For those of you who are as unaware as I was , the Taurus fan supposedly flows 2700cfm on low and 4000cfm on high speed . I found one at the local pick-n-pull junkyard for just under $25 out the door .
... A few years ago I tried a Flexalite Cyclone 16" that was rated at 2500cfm ... it turned out that the stock fan did as well if not better so for the sake of simplicity , the stocker went back in .
... The reason I brought up the Flexalite is because it became the donor for the mount for the Taurus 2 speed fan ... check it out ... the missing grate pieces were removed for mounting clearance on the car ... the Taurus motor is a 1/4" larger in diameter than the Flexalite so I cut out the center of the mount with a saw-tooth dremel bit .
... This write-up is forensic since I had to find out if it would work and didn't think to take photos beforehand ...
... Next , I cut the center out of the original Taurus mount/shroud to use for the screws to attach both parts together .....
... Then , after filing a bit off the insides of the screw bosses for clearance , I sandwiched the pieces together and bolted it all up .....
... I will post a follow-up on evaluating the performance of this set-up as soon as the outdoor temps give me a realistic way to quantify the results ...............
Old Jan 9, 2011 | 10:50 AM
twin540's Avatar
twin540
How is the two speed going to work?
are you going to run the taurus relay as well?
Old Jan 9, 2011 | 10:56 AM
C409's Avatar
C409
....... I already have a separate 40amp relay wired in from when I used the Flexalite fan ... I will run the low speed off the factory relay through the normally closed terminal and high off the NO term on the aux relay with the ECM wire and full-time toggle switches attached to both ...
Old Jan 9, 2011 | 11:12 AM
twin540's Avatar
twin540
Nice, keep us posted.
Old Jan 9, 2011 | 05:51 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
Ditto
Old Jan 9, 2011 | 07:07 PM
frank carlson's Avatar
frank carlson
Default Taurus fan install
Can you specify what year model taurus to source for the fan. Is it a specific year only or a range of years? Thanks
Old Jan 9, 2011 | 08:19 PM
C409's Avatar
C409
As I understand it ... we're looking for '95-'98 ... the later ones seem to have dual fans with a primary and secondary ... Some Mustangs may have also used the two-speed fan/fans ... just google Taurus Fan for some interesting reading ... Mine came out of a '97 ... It helps a lot if you have a pick and pull style junkyard that you can hunt in and get measurements and compare shrouds and such ... I had a mounting frame that I knew would fit the Corvette and didn't have to modify the factory shroud ..... STAY TUNED ..................
Old Apr 26, 2011 | 03:30 PM
C409's Avatar
C409
........... Two speed Taurus fan update ..... this thing is awesome ... I run the fan on low speed ( about the same flow as factory ) at all times ... I have a three position toggle switch with down for low , middle for off , and up for high ... anyway , on the low speed setting the car generally runs around 184* in traffic , upper 160*s on the interstate ..... During spring break , I was trolling the beach in bumper to bumper traffic 88* air temps and let the engine temp creep its way up to 200* ... this is with low speed fan running ... then I turned it to high speed and within 2-3 minutes ... still in traffic ... the temp had dropped to 178*... I get the same results in drive throughs ..... between rounds at the track it takes about 20 seconds on high speed , engine off , to get ambient air temps through the radiator ..................... No concerns about turning on the AC in traffic anymore ... this is great !
Old Apr 26, 2011 | 04:10 PM
STL94LT1's Avatar
STL94LT1
I'm pretty sure Crown Vics used the same fan. I'm running one on my truck and it sounds like a Turbo Prop on high speed.
Old Apr 26, 2011 | 04:28 PM
Aardwolf's Avatar
Aardwolf
Is there a part number for the fan?
Old Apr 26, 2011 | 05:46 PM
JackDidley's Avatar
JackDidley
I triedto do that a couple years ago. Could not figure out a way to mount it that would not look like a hack job so I gave up. You did better than me.
Old Apr 26, 2011 | 11:51 PM
C409's Avatar
C409
..... I'm sure there is ... but I shopped at the local LKQ pick-n-pull junkyard ..... The Taurus has a 16inch blade ... same as the vette ... the Crown Vic / Grand Marquis has an 18 incher ............ the Ford shrouds could be hacked in ... if carefully done , it wouldn't necessarily be all that obvious ...... Happy Hunting ! ..... Cop car fan motors are heavy duty , meant for long term continuous duty .......................
Old Apr 27, 2011 | 05:59 AM
rv34's Avatar
rv34
The fan is from a 1990-1995 3.8l Taurus, sable, and lincons. Ive used it, and they are awesome. On my trans AM on low standing a foot in front of the car with the fan on low, you can see my leg hair being sucked toward the fan. It works great.
Old Apr 27, 2011 | 08:13 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Nice work
Thanks for remiding me about the fan, can't remember the thread I read that originally got me thinking about the taurus fan.
Old Jun 3, 2011 | 01:46 AM
oldalaskaman's Avatar
oldalaskaman
Just wanted to say thanks, for this thread, got my taurus 2 speed fan today, respectfully, bob
Old Jun 3, 2011 | 08:49 AM
ggrassmid's Avatar
ggrassmid
interesting read; I may have to look into this for autocross event during mid summer.
Old Jun 3, 2011 | 01:01 PM
twin540's Avatar
twin540
Can you make another step by step thread including wiring/switches? This would be a great upgrade. Thanks in advance
Old Jun 3, 2011 | 03:13 PM
oldalaskaman
I will as soon as I start it, getting the weatherstripping done and then on to that.
To Taurus 2-speed Fan Install
