Been a busy week...Lots o' pics.
Old Jan 11, 2011 | 09:11 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Default Been a busy week...Lots o' pics.
Been busy the past 4-5 days. Started out with the engine freshly pulled from the car last Thursday. By Sunday, the transmission was bolted up with the C-Beam. Had a few setbacks, but nothing substantial.
I want to thank a few people:
Apple's Machine shop in Yorktown, VA. They had the block and heads back to me in less than a day, and overnighted pistons for me, and pressed them on the rods free of charge.
Atlantic Speed. Super fast shipping and always good to deal with.
Z51 Performance (Bill Bordeau, AKA ZFDoc) Awesome product and lightning fast shipping.
What was done:
Cleaned and honed the block.
Polished crankshaft main and rod journals.
New Clevite H series bearings. (Main and Rods)
New camshaft bearings.
ARP main bolts.
New flat top Speed Pro hypereutectic pistons with 4 valve reliefs. (One of the original pistons had a broken ring land between the compression rings.)
New oil pump. Melling standard volume/pressure.
Canton road race pan and pickup.
New Comp Cams camshaft.
New hydraulic roller lifters.
Heads were cleaned, decked 0.010", New double valve springs, seals, valve guides, retainers, seals, and keepers.
Crane 1.6 roller rockers
New intake manifold. (wiring is a mess, going carb)
New Headman Elite's
New SPEC aluminum flywheel.
New SPEC Stage 1 clutch.
New clutch slave cylinder.
New Hurst shifter (Thank you Atlantic Speed)
New Hurst shifter Ball (Thank you again, Atlantic Speed, since Hurst was absolutely no help)
Z51 Performance C-Beam Plates (Thanks so much Bill Bordeau, they are amazing)
TPiS A/C Delete
I'm still waiting on parts to finish the fuel system. I have a DeWitt's radiator on the way. Working on the exhaust now, a little at a time.
On to the pictures!!!!
Let the teardown begin:
Top end coming apart:
Heads off:
Back from the machine shop:
New cam going in:
Big lobes. BIG lobes.
Home sweet home:
New pistons:
Slugs in:
Almost together:
Ready to go in:
Back where she belongs:
Headman Elites:
Flywheel on:
Clutch in:
Shifter installed:
New shifter ball:
Transmission at home:
C-Beam Plates:
Why buy when you can fabricate?!
Old Jan 11, 2011 | 09:17 PM
RED-85-Z51's Avatar
RED-85-Z51
Any pics of your gauge setup? Looks nice, how do you like it?
Old Jan 11, 2011 | 09:19 PM
tblt44's Avatar
tblt44
purty
Old Jan 11, 2011 | 09:20 PM
Black89Z51's Avatar
Black89Z51
It looks like a hurricane and a tsunami went through it right now. I will post some when I get things picked up. I like everything so far. Haven't had a chance to fire it up yet. At least until I get the fuel plumbing ran.
Old Jan 11, 2011 | 10:47 PM
Pwnage1337's Avatar
Pwnage1337
wow, thats extremely fast turn around time. very nice!
Old Jan 11, 2011 | 11:15 PM
cgantner5150's Avatar
cgantner5150
Almost did mine that fast - going on 6 months or so - and still going on.
EXCELLENT JOB.
Old Jan 12, 2011 | 12:04 AM
dogfish246's Avatar
dogfish246
Thats really cool!
Old Jan 12, 2011 | 06:29 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
You mentioned ARP Main bolts. What about the three extended bolts for the baffle/windage tray? Are they ARP too? I'm looking to do ARP main bolts or studs for my rebuild and am not sure about these three. I found an ARP main stud kit for sbc with windage tray (ARP-234-5501), but not sure if it'll be right.
Old Jan 12, 2011 | 08:59 AM
Black89Z51's Avatar
Black89Z51
Since I used the Canton Road Race pan, the stock main bolts wouldn't allow the pan to be installed. The ARP Main bolts I used were PN 134-5001. If you are using the stock oil pan, I don't see a problem with using the windage tray. Keep in mind that if you are going with main studs, it's a very good idea to get the mains align honed.
Old Jan 12, 2011 | 02:26 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Mains are getting align honed so no problem there. I saw the first picture of your block back from the machine shop and saw the windage tray bolts on #3 and 4 main and thought that these were ARP from somewhere. Now I realize that it was before the ARPs and they are the stock bolts. I guess I'll order the 234-5501 kit and see if it has the three for the windage tray. Thanks for the input and good luck with your project.
Old Jan 12, 2011 | 06:09 PM
Black89Z51's Avatar
Black89Z51
Thanks for all the kind comments from everyone. I have a huge order coming in Friday that should button things up and allow me to hear it run. There will definitely be a video on that.
Just a little update. Got the exhaust almost done, just waiting on mufflers now. I won't be going all the way out, They will dump just before the rear diff.
Old Jan 12, 2011 | 08:10 PM
ch@0s's Avatar
ch@0s
Won't that give you an awful drone?
Gl BTW
Old Jan 12, 2011 | 09:00 PM
Black89Z51's Avatar
Black89Z51
Gl BTW
I don't think I'll be doing too much cruising with it.
Old Jan 12, 2011 | 09:07 PM
ch@0s's Avatar
ch@0s
OH I see .. who cares then
Old Jan 12, 2011 | 09:45 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
Old Jan 13, 2011 | 06:56 AM
Black89Z51's Avatar
Black89Z51
For some reason I read "garage" instead of "gauge". But as requested, here is the pic I had just after I installed it. And I love it. Only thing I don't like is that the high beam indicator is too bright at night.
To Been a busy week...Lots o' pics.
