Smell raw fuel while trying to start
Old Jan 12, 2011 | 12:29 PM
FOXX's Avatar
FOXX
Default Smell raw fuel while trying to start
Lately it's been getting harder and harder to start in the colder wet weather. Not sure what it could be. I usually seem to get it to start after minutes of trying but now it will not start at all. It will turn over but not fire. It sounds like it tries to start but just won't stay running. Why am I smelling raw fuel? Could the injectors be crap? Could it be the fuel pressure regulator allowing fuel to dump in the cyl and flood it?
93 6speed
I should probably mention, it doesn't have a fuel leak. I looked. I smell the raw fuel out back by the exhaust.
Old Jan 12, 2011 | 12:39 PM
pay the mechanic's Avatar
pay the mechanic
chech your plugsssssssssssss
Old Jan 12, 2011 | 12:47 PM
ch@0s's Avatar
ch@0s
You might have injectors leaking and fouling your plugs. Are they the original Injectors?
Old Jan 12, 2011 | 01:05 PM
FOXX's Avatar
FOXX
I'm not sure but I would think yes, they are original. Car has 178,000 miles.
Is there a way to check for leaking injectors? If so, how?
Thx
Old Jan 12, 2011 | 01:13 PM
dogfish246's Avatar
dogfish246
Use a fuel pressure tester and tell us what you get... They can be found for $20 online or $40-50 in retail stores... Its a good investment!
Old Jan 12, 2011 | 01:28 PM
FOXX's Avatar
FOXX
I'll get a pressure tester and let you know.
Question. If it doesn't start right away, will gas normally keep pouring in to allow it to start?
Old Jan 12, 2011 | 01:40 PM
ch@0s's Avatar
ch@0s
As long as you turn the key it will keep pouring in. If you get enough gas it will wash past the piston rings into your oil.Check your oil if it has gas in it change it immediately. You also need to ck for spark at the plugs.
Old Jan 12, 2011 | 03:04 PM
FOXX's Avatar
FOXX
Ok I'll check that too. Would you know why it starts fine when it's warm? It's when I let it sit overnight and try to start it in the morning it gives me hell and is almost impossible to start. What part(s) does that sound like?
Old Jan 12, 2011 | 03:51 PM
pcolt94's Avatar
pcolt94
I'll bet the fuel pressure regulator (FPR) is defective. Overnight the fuel is coming back thru the vacuum line into the manifold and filling it with fuel. So in the morning you are loaded up.
Pull off the vacuum line of the FPR and see if it is wet with fuel. You can also turn the key to on, then off to pressurize the system. Then take the vacuum line off watch and see if it drips. If it does it is bad.
You can also connect a short hose on the FPR and put hose in cup and see and measure what comes out.
Old Jan 12, 2011 | 06:09 PM
overdrawn's Avatar
overdrawn
Old Jan 12, 2011 | 08:35 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
My 89 had similar symptoms. The scary part was fuel was working its way through the throttle body and leaking out the air filter. I have a gas water heater in my garage. Fortunately no fumes hit the pilot. The FPR cured my problem.
Old Jan 12, 2011 | 10:09 PM
FOXX's Avatar
FOXX
Ok, I'll do the FPR thing tomorrow. Would it be best to do it prior to trying to start it in the morning to make sure any fuel is out of the intake or should I do it after I get it started, "if" I get it started?? That way I could see if it worked the following morning.
I looked in my factory service manual and there's really not much about the FPR remove/replace functions. Any tips on how to do that?
Old Jan 13, 2011 | 12:33 AM
phat87's Avatar
phat87
2021 C4 of the Year - Unmodified Finalist
Default load test
Load test your battery. If it does it when it is cold it could be your battery is getting ready to puke. A cold, weak , (sacked) battery can have enough juice to turn the engine over like gang busters but nothing left for the secondary circuit.
Just a thought.
Old Jan 13, 2011 | 10:56 AM
FOXX's Avatar
FOXX
I should've mentioned that the battery is brand new. 3 weeks old.
Old Jan 13, 2011 | 12:21 PM
pcolt94's Avatar
pcolt94
Good plan, I would start it in the morning and get it all cleaned out But don’t get the engine hot.
Then right away I would depressurize the system. If you have a fuel pressure tester with a pressure release button and output vent, put a hose on it and dump fuel into a cup. Or use any way you're comfortable and get some paper towels for spillage.
It is an easy replacement, a few bolts and hose connections and your done.
When mine went bad, it would dump almost 2 ozs of fuel into the engine over night. I felt like I had a new engine after it was replaced.
Old Jan 13, 2011 | 12:53 PM
aklim's Avatar
aklim
I would check the FPR first. Pressurize the system and see how fast the fuel drops. If it falls quickly, clamp off the return line and see what happens. If it stops falling off, the FPR is shot.
I don't bother to check the fuel injectors. Nothing I have to check it with anyways. After 178K, I can't see anything wrong with taking it out and sending it off to FIC for a cleaning and check.
If it were me, I'd replace the FPR at the same time too.
Old Jan 13, 2011 | 05:41 PM
FOXX's Avatar
FOXX
I'm going to tear into it tomorrow morning and do the FPR. I didn't see anything in the FSM about this but I'm assuming the injector rail will have to come off. After looking at it, that was my guess.
I do intend on having the injectors gone through. Who is FIC? I hear it's cheaper to get the oem injectors rebuilt than to buy new ones.
To Smell raw fuel while trying to start
Old Jan 13, 2011 | 06:02 PM
aklim's Avatar
aklim
It has been so long since I was stock I don't remember but I would think it has to come off. During which time you can clean the TB. Take it and the IAC housing off and clean them THOROUGHLY.
http://fuelinjectionconnection.com/
Old Jan 13, 2011 | 07:45 PM
ch@0s's Avatar
ch@0s
Here is a fuel injector install it will also give you an idea of what's involved in replacing the FPR diaphragm.
Sammy Calderone's step by step install
Old Jan 15, 2011 | 06:49 AM
FOXX's Avatar
FOXX
Ch@os, thanks for the vid. I have the LT1 and this appears to be L98? My distributor is under the water pump in the front of the engine though. Does anyone know of a walkthrough on the FPR replacement? I went to a mechanic shop yesterday and they quoted me 2 hours @ $80 per hour! That's $160 for this fix! Fu&$ that! I didn't do it. This has to be something that shows up in the FSM but I just can't find it and really starting to wonder why. We even looked in a Chiltons and didn't find it. If you find it in your FSM please let me know what page it's on. Thanks
