Is 85 to 89 wiring the same?
Old Jan 12, 2011 | 07:47 PM
pipe's Avatar
pipe
Default Is 85 to 89 wiring the same?
Is the Engine Wiring Harness from a 85 to 89 the same or different? Pipe
Old Jan 12, 2011 | 08:07 PM
Sandpiper59's Avatar
Sandpiper59
I could be way off here but it looks like there are options available in 89 that were not in 85 so certainly wiring would be different, someone will certainly ask... Do you mean a specific harness or just all wiring in general?
Old Jan 12, 2011 | 08:18 PM
rodj's Avatar
rodj
Different
85 has crappy one year only MAF setup with different burnoff setup.
85 harness can be converted to 86 -89 configuration if you use the later relays and repin ECM connectors
Old Jan 12, 2011 | 08:52 PM
John A. Marker's Avatar
John A. Marker
with rodj.
Old Jan 12, 2011 | 09:56 PM
redrose's Avatar
redrose
85 is 'unique', pita to repin to 86-89 type -165 ecm but possible if highly motivated.
89 lost cold start sensor/timer wires and 9th injector wires.
IIRC there are also a few wire color variations between MY's
part way thru 89, wire insulation was upgraded.
Old Jan 12, 2011 | 10:54 PM
Muffin's Avatar
Muffin
Wouldn't call the 85 crappy. Call it a major step forward, basic, innovative but not crappy. The Burn off module was a means to an end. In most cases has worked well for a lot of years. Oh yes, the 85 ECM is very slow in output compared to say 86, but faster than anything prior. 85 ECM and MAF burn off can be upgraded to 86-89 in about an hour if you do your homework.
Give you three guesses who proudly drives an and has done the ECM upgrade.
Old Jan 12, 2011 | 11:28 PM
rodj's Avatar
rodj
Originally Posted by Muffin
Wouldn't call the 85 crappy. Give you three guesses who proudly drives an and has done the ECM upgrade.
I was referring to its design ( expensive replacement module instead of relays ) and placement under the dash ;
not it's functionality
Old Jan 13, 2011 | 07:00 AM
LD85's Avatar
LD85
just an fyi, you can send your 85 harness to www.jimsperformance.com and for @ $125-$150, he will repin it to match the 86-89, replace broken connectors, add or replace wires that you might require and do a diagnostic on the harness.
Old Jan 13, 2011 | 07:34 AM
856SPEED's Avatar
856SPEED
Good info:
Old Jan 13, 2011 | 08:11 AM
LD85's Avatar
LD85
Originally Posted by 856SPEED
Good info:
Thanks, Jim found an intermittent ground short in my harness, I would NEVER have found that on my own.... ground issues are huge problems on an FI car and I would have chased my tail for who knows how long...
Jim is an excellent resource.
Old Jan 13, 2011 | 08:35 AM
Muffin's Avatar
Muffin
I am sure his work would be a super professional job also. I did mine in my garage, pins, relays, ECM and aluminum for a relay bracket set me back about $75.00. May not be as pretty but it works.
And now the rest of the story: A CalPac from the Chebby Sto cost me $75.00, a new chip was $6.00 and $350.00 ( this is a WAG) for the hardware and software to program the chip.
Old Jan 13, 2011 | 11:05 AM
oldalaskaman's Avatar
oldalaskaman
the biggest differences I found when doing something as simple as upgading the headlights on my 87 to a 92, or three wire to two wire , was that the color codes on the wiring had changed. I suspect the differences you are asking about would involve the same issues
Old Jan 13, 2011 | 05:29 PM
pipe's Avatar
pipe
Thanks for the Reply's everyone. The Wiring Harness in my 88 is kinda hacked up plus it is from a 4+3 car which I want to Change over to a Automatic since i'm going to Race it regularly. Isn't the Wiring for the Trans merged in with the Engine Harness? So a 86 to 88 is a safe bet it will be a plug and play deal? Is the Connectors the same where they plug into the Firewall by the Battery and the Bulkhead where it goes through the Firewall into the ECM? THANKS FOR ALL THE HELP Pipe
Old Jan 13, 2011 | 07:48 PM
oldalaskaman
on generalized questions like that, I vote , yes
Old Jan 13, 2011 | 08:03 PM
1985 Corvette's Avatar
1985 Corvette
I'm doing something similar. I'm running a complete bumper to bumper 4+3 harness out of an 86' in my 85'. I've "pinned out" the AIR diverter solenoid and AIR switch solenoid wiring and removed it all. It was done properly so it can be reinstalled if necessary.
Was planning to just run a pulley in place of the AIR pump, block the egr provision in the manifold, and cap the fuel rail as well as eliminate the cold start injector.I've read a few post saying ditching EGR wasn't suggested. Haven't quite made my mind up yet. Guess we'll see what kind of fireworks I get when I hook it all up and try to run some current through it...
By the Bye: Can anyone tell me where the blue wire running off the ESC plug goes to? I checked the 86 wiring diagrams and if I'm reading it right it goes to a knock sensor which also is drawn as a ground. I spliced on a new ESC pigtail only to find that the blue wire runs to nothing once I fished it out of the bundle. Not entirely sure how this could have happened.
To Is 85 to 89 wiring the same?
