Stroking
Old Jan 16, 2011 | 07:19 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Default Stroking
Going to stroke my '86. Looking for opinions from those that have used any of these components:
Scat 435050L crank
Scat 6600021QLS rods
SRP 138093 pistons
I know that a forged rotating assembly is overkill for the power I'll be making now, but looking ahead. Just looking for opinions from those that have used these parts.
Thanks.
Old Jan 16, 2011 | 08:29 AM
96 lt-4's Avatar
96 lt-4
You will be fine with all of the above.Just make sure you have the machinist check all clearances.Not everything is spot on out of the box(no matter who makes it).
Old Jan 16, 2011 | 10:47 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Understood, many thanks for your input.
Old Jan 16, 2011 | 11:46 AM
Raidmagic's Avatar
Raidmagic
Damn Ray, I thought you were just going to do heads and intake? Once you start you just can't stop!
Old Jan 16, 2011 | 11:53 AM
ch@0s's Avatar
ch@0s
You're telling me? I have been looking for a 84-85 C4 to do a LSX swap with.
Here's your hew song Ray:
Old Jan 16, 2011 | 04:33 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Yea Steve, this all started as an engine bay clean up!
Old Jan 16, 2011 | 04:35 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Not exactly the kind of stroking I had in mind Rafie! Good one though.
Old Jan 16, 2011 | 05:18 PM
cumbercr's Avatar
cumbercr
As long as you're going forged internals, why not stroke for a 396? The crank is the same cost. With some different rods, the clearancing required is nearly the same.
My 396 is being assembled now using an Eagle 4340 crank, SRP pistons and Crower rods. I went with Crower Sportsman Stroker rods to minimize clearancing and allow use of a standard base circle cam. The additional Hp and torque is pretty cost effective when compared to other mods.
Old Jan 16, 2011 | 09:03 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
That's and excellant point, Craig. I'll have to check with the machine shop. I don't think I can afford those Crower stroker rods though and I'm not sure how confortable I am with clearancing for a 396. 383 may be my limit on this one. Thanks for your input.
Old Jan 17, 2011 | 12:10 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Scat 435050L crank
SRP 138093 pistons
Forged is overkill for the power I'll be making now, but looking ahead. Just looking for opinions from those that have used these parts.
Thanks.
I used the crank...so far no problem. Many, many builders like this best for a non-forged option.
$500 rods? Really? Why? $200 gets a good set. For the extra $300 go with a forged crank!
Pistons look like a great choice. 4032 allows for tighter clearnance when you're installing forged pistons.
Old Jan 17, 2011 | 01:20 PM
Davejs's Avatar
Davejs
The main thing with doing a 383 is heads and intake do not breath at all. I just got my 383 off the dyno a couple weeks ago and with good heads and intake 450hp 465tq and that was a small HFT cam.
Old Jan 17, 2011 | 01:39 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Gregg, That Scat 435050L crank is forged. For the rods I was trying to go a bit lighter and these seemed reasonable. Thanks for the input. Looks like nobody has had any horror stories with these parts. That's a relief.
Old Jan 17, 2011 | 02:55 PM
GREGGPENN's Avatar
GREGGPENN
Sorry. Mine's the 935050L. I'd forgotten the first digit.
Since you looking for lighter, have you considered the Professional Series of the SRP line...
http://www.jepistons.com/Catalogs/SR..._flat-pro.aspx
Old Jan 17, 2011 | 05:50 PM
BLUE ONE's Avatar
BLUE ONE
Ray im going with Scat crank and stroker rods and Icon pistons from performance unlimited.
By the way im Mark, been talking to you about ARP head bolts tonight.
Old Jan 18, 2011 | 03:25 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Gregg, I wish you hadn't mentioned them. In a perfect world, I'd go both with the pistons you pointed out and the lighter H-Beam rods I've ordered, but for me, it's not a perfect world and these pistons are about $100 more. I could go with the Scat I beam rods and save $200, then go with these pistons and still save $100 of what I'd originally budgeted, but the pistons shave about 25 grams, the rods shave 36. Thanks for the info, in the end I'll probably go with both. I'll find the extra $100 somewhere.
Old Jan 18, 2011 | 03:27 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Mark, you going with the same forged 435050L crank and 6600021QLS ultra light rods?
Got your email. Selling the bolts will allow me to buy the lighter pistons.
Old Jan 18, 2011 | 03:23 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Sorry, when I saw the thread title I expected to see a hot chick.
To Stroking
Old Jan 18, 2011 | 03:48 PM
GREGGPENN's Avatar
GREGGPENN
Gotcha. I don't know if you're driving a stick or auto. I decided against the light-weight stuff just because the DMF is so friggin' heavy. Kinda hard to offset all of it's weight, don't-you-know!
As for the 25g vs 36g decision, I'd wonder if lighter weight further out from the crank translates to a bigger inertia savings. IOW, I gotta wonder if the RA "sees" more of the piston weight than the rods. RA is one thing. The reciprocation issue has to be another.
There could be other frictional differences between the two piston options as well. I haven't compared what you're selecting to the Pro line, but I came away pretty impressed with the SRP Pro stuff after I read/learned about it!
Old Jan 18, 2011 | 04:58 PM
BLUE ONE's Avatar
BLUE ONE
Same 6inch rods but cast 9000 crank, no plans to upgrade further so should be fine for my application........but with 400g forged piston weight to allow internal balancing and std size 350 damper to clear cross member.
Old Jan 18, 2011 | 05:20 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
I see what you mean Gregg. I have the 4+3 so a standard flywheel. I've ordered those SRP Pros you mentioned #268830. Hell it's only money, if I didn't spend it on this, I'd spend it on something stupid like food or clothes. We'll see how it goes. Many thanks.
