Instrument panel light replace on 85 Corvette coupe
Old Apr 10, 2002 | 12:10 AM
Danny Downen's Avatar
Danny Downen
Cruising
Default Instrument panel light replace on 85 Corvette coupe
How do you get to those back-lighe bulbs behind the digital instrument panel?
I recently had the dash cover off, but don't remember seeing any bulbs from the top....Please advise if you've 'been there, done that'. Thanks.
Old Apr 10, 2002 | 12:13 AM
scorp508's Avatar
scorp508
Ok remove the bezel in front of the instrument cluster. This also requires removing.
1. Headlight switch ****.
2. Tilt-wheel lever. (Tilt the wheel down and out all the way first.)
Then it is just a bunch of screws, and pull it off carefully.
You will see 4 silver plugs that you cna pull out. Behind those are the bulbs. :)
Old Apr 10, 2002 | 08:06 AM
Joe C's Avatar
Joe C
Default Re: Instrument panel light replace on 85 Corvette coupe (Danny Downen)
danny -
if you haven't bought your new bulbs, don't go to your local GM dealer, if i'm not mistaken, they go for somewhere around $10 each (???). anyway, get replacement bulbs from a local NAPA dealer. they are GE bulbs - probably the same that GM uses. they are about 1/2 price. while you're at it, replace all 4 bulbs at once - if not, as soon as you put the last screw in, another bulb will go out - hope this helps
BTW, welcome to the forum!
[Modified by joe ciechanowski, 6:08 AM 4/10/2002]
Old Apr 10, 2002 | 06:07 PM
Danny Downen
Cruising
Default Re: (scorp508)
Thanks a bunch for the info. I'm new to the Corvette world, and so far, it's been a gas... :D
Old Apr 10, 2002 | 06:10 PM
Danny Downen
Cruising
Default Re: Instrument panel light replace on 85 Corvette coupe (joe ciechanowski)
Joe,
Thanks a bunch for the info. I'll surely make a trip to the NAPA place for All the bulbs as you advised. I'm new to Corvettes, and so far it's been a gas!
danny d
:chevy
To Instrument panel light replace on 85 Corvette coupe
