Solid top insulation pad
Old Jan 18, 2011 | 04:55 PM
HlhnEast's Avatar
HlhnEast
Default Solid top insulation pad
When I swapped over to the solid top I had to redo the headliner and its already starting to come loose again. I used the good 3M adhesive but I think the insulating pad is starting to come apart and even if I redo the headliner it will probly keep coming loose. I also lost headroom because of the thick fiberglass pad. Has anyone used a thinner insulator like ensolite foam or similar to replace the fiberglass one? I figure maybe two thin layers of foam would offer the same heat resistance and give me back a bit of room. The 3M adhesive should have a better base to stick to as well.
Thoughts?
Old Jan 18, 2011 | 06:13 PM
MyFirst90coupe's Avatar
MyFirst90coupe
Have the same question
Old Jan 18, 2011 | 07:21 PM
RICEKILA's Avatar
RICEKILA
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
I put two layers of thin Duct insulation - but didnt get around to the headliner yet
In the summer when the outside is 900 degs. and I cant put my hand on it longer than 5 sec. --- the inside is just warm to the touch
PS - it's the peal and stick-ie stuff --- hasn't come off in two years now
Old Jan 18, 2011 | 09:05 PM
George Dickel's Avatar
George Dickel
I remember on the Power Block TV show, Trucks I believe, they re-did a headliner for a truck restoration. You have to remove all the old foam from the hard fiber form and glue new rubber padding on and then the new headliner material.
Old Jan 19, 2011 | 05:23 AM
HlhnEast's Avatar
HlhnEast
Did you hafta get this at a A/C wholesaler or is it available at HD or Lowes? Lowes has a kind of bubble wrap like the shipping stuff lined with foil which I didnt like. I would like to find a sheet of the black dense foam stuff. I have seen it in narrow rolls for wrapping the copper freon lines but not anything wider than 6 inches.
Old Jan 20, 2011 | 12:38 AM
RICEKILA's Avatar
RICEKILA
I got it at Home Depot -- Called "Frost King" - 12" wide X 15' long roll, foil on one side and just sticky stuff on the other
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
I pealed / wire brushed off the lite foam off of the molded Styrofoam.
I even bought the black headliner material and spray glue from Many - Mo and Jack. All I need is the 1/4" soft foam and the desire to finish it
PS - Dont try to apply it to the top - outside on a windy day
To Solid top insulation pad
