86 brake master cylinder question
Old Jan 19, 2011 | 06:13 PM
Jeffwilson34's Avatar
Jeffwilson34
Default 86 brake master cylinder question
Does anyone know what years a brake master cylinder will fit an early 86.
It has one round reservoir on it but when I looked at a replacement there was 2 reservoirs.
Do I have an oddball or dud I get an guy at the part store that just got the wrong part?
Old Jan 19, 2011 | 06:54 PM
pmihaltian's Avatar
pmihaltian
Slingshot
The 86 Vettes came with a one reservoir master cylinder. You should be able to fine one at the many Corvette parts houses.
http://www.ecklers.com/corvette-clut...1984-1988.html
Old Jan 19, 2011 | 08:35 PM
Jeffwilson34
thanks for the info.
Old Jan 19, 2011 | 10:26 PM
cgantner5150's Avatar
cgantner5150
My 86 has two reservoirs on it but it seems to be a mutt with an 88. I was wondering what is the difference between the two?
Old Jan 19, 2011 | 11:46 PM
rodj's Avatar
rodj
The bodies appear the same; only the reservoir config is different.
I have '87 ( single ) and '89 /'90 ( dual ) MC's here and all have the same PBR casting # on the body
Is a clutch master cylinder
Try this one ; 86/87 MC
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
Old Jan 20, 2011 | 01:00 PM
oldalaskaman's Avatar
oldalaskaman
bench bleed it prior to installing and you will only have to do minimal if any bleeding the 86-87 have single res's like the clutch . I had trouble getting one from the venders and went to Kragens and got a rebuilt one for $82, hope this helps
Old Jan 21, 2011 | 10:22 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Oh your right, Rod. Sorry
To 86 brake master cylinder question
