Timing Chain / Harmonic balancer
Old Jan 20, 2011 | 05:30 PM
eaglevision993's Avatar
eaglevision993
Default Timing Chain / Harmonic balancer
Hi,
since it will be winter for some more time and I can´t drive the Vette anyway, I think about doing the timing chain and the harmonic balancer.
None of them seem to be an acute problem, but with 85k miles and 23 years I feel better to get them done.
Maybe it will cure the ultra light vibration at idle....
I have a Haynes manual, not yet factory manual but I think I can do the job with some prior hints from you!
My first question: Single or Double Roller timing set?
As for double roller, will this fit?
CLOYES Part # 91145 Street True® Roller Set; High Performance (rockauto, around 70 US$)
Any hp losses from running a double roller?
Anything needs to be grinded/modifies to fit?
As for the harmonic balancer I´d use a ACDELCO Part # 12551537 , seems stock replacement.
The engine runs strong and excellent, I did a complete top end overhaul when I did my headgaskets so I do not want to bent valves or anything....please let me know any precautions.....
Best regards
Benjamin
Old Jan 20, 2011 | 05:32 PM
eaglevision993
In case the single roller would be a better choice , will this be ok?
CLOYES Part # C3092 More Information About this Part Heavy Duty Timing Set; Cam, Crank, Chain
Incl. Cam Sprocket; Heavy Duty Timing Set; Crank Sprocket; W/0.5 In. Pitch Single Roller Chain
Old Jan 20, 2011 | 06:08 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Originally Posted by eaglevision993
Hi,
Best regards
Benjamin
If you go double roller you may need to grind part of the oil galley boss above the cam to get it to fit. I had to do this on my 89 L98 but afterwards everything fit fine. I used the S.A. Gear performance set.
Old Jan 20, 2011 | 06:28 PM
eaglevision993
Hm...ok, that sounds doable....
One more thing, most good Timing Sets have several keyways which retard or advance timing by + - 4 degrees.
Advancing should bring a little more low end power, but are there any drawbacks, such as idle quality or emission problems?
I mostly drive in the lower rpms, therefore maybe worth doing it while I´m in there?
To Timing Chain / Harmonic balancer
