...what other stuff should I be looking at? How should the starter gear teeth look? Should I get a mini-starter since headers are going on to help with clearance and heat? Or just sheild my current one?
I think you went with 1"3/4 right? I have the LPE's obviously..and no wrap on the starter. I think ralph had a problem a while back with heat soak...But I never experienced it.
That's amazing your rear main isn't leaking. If that we're my car, I'd get everything back togehter,and it'd start leaking....=bye bye clutch. If it isn't broken(I hate the word AIN'T) don't fix it.
I'll take a pic of the rear of the crank when I get home. There is a very very small amount of oil. I'm just worried that taking the stuff off required to do that will disturb too much else right now.
Yes, bogus your rear main seal is easy to do it's a one piece, But I think scorp had a two piece deal where he has to drop the pan am I correct Scorp?
I beleive that late 86 was the introduction of the 1 peice seal. It was introduced at the same time ast he aluminum heads.
Scorp if you have that it's cake to do remove the bolts take the seal housing and seal off and get it out of the housing but don't nick the surface where the seal sits in the housing if you find a round something that will fit the seal so you can bang it off with the housing resting off the ground it won't be that hard.
You probably already have the small ND starter; the replacements aren't much smaller or lighter.
Heat shields are better for deflecting radiant heat; the wrap acts more like a fire suit- it slows down the progression but if applied long enough the heat will eventually get thru.
That being said, I've had headers for 4 years and never had any starter trouble.
