temp sensor
Old Jan 22, 2011 | 03:02 PM
ChrisWhewell's Avatar
ChrisWhewell
Default temp sensor
fixed a coolant leak but broke the temp sensor that threads into the water pump housing on the front of my 93 - grrrr.
Anyone got a part number for that little sensor handy ? Better yet, got a spare ya wanna sell me
Old Jan 22, 2011 | 03:09 PM
ChrisWhewell
Originally Posted by Pete K
If it is the brass, 2 prong with the oval wiring connector, they are dirt cheap, and in stock at every parts store.
Kick@zz. Thanks. I'll fire up the Road King and go git one.
Old Jan 22, 2011 | 04:50 PM
STL94LT1's Avatar
STL94LT1
Chris make sure you get the coolant temp sensor (CTS) for the ECM, not the analog temp gauge. There is a difference.
Old Jan 22, 2011 | 09:05 PM
ChrisWhewell
Thanks. Its all good now, I passed the state inspection too. Sensor was $ 12.
Had a headlight out, changed the thing, still didn't work. Traced it to a broken wire at the 3-prong connector. Age. Somehow I extracted the little copper SOB and was able to open up the crimp and solder the bstrd. Changed the other side so I have two new headlamps, shouldn't blow out for a while I hope.
To temp sensor
