Rear spring broke.....
Old Jan 22, 2011 | 07:45 PM
northbender42's Avatar
northbender42
Default Rear spring broke.....
I am putting a complete poly kit and i finished the back and lowered it and it was sitting high and the tires were towed it so i thougt it would relax and seattle down. Well i had the front up and removing the control arms and i heard some creaking in the back and noticed that the back had squated down and it was a little lower than when i first started but i had the front up so i thought that what was causing that. Well i finished the front today lowered it and it was still very low in the rear so i looked underneith the rear and the damm spring broke. Tell me am i sappose to lower it loose and tighten it did i do something wrong becouse the front is high till it relax's and dont want the front spring to break.....
Old Jan 22, 2011 | 08:24 PM
vetteoz's Avatar
vetteoz
Done something wrong.
Never heard of a spring breaking while car sitting
Where did spring break?
Pics?
Old Jan 22, 2011 | 08:27 PM
Pete K's Avatar
Pete K
Did you clean the spring with soap?
Old Jan 22, 2011 | 08:44 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Mine broke.
Old Jan 22, 2011 | 08:48 PM
87 vette 81 big girl's Avatar
Thats bad news.
Did you clean the rear spring with a solvent degreasor ? Or use an acidic or caustic cleaner on it ?
I Never Knew that you are not supposed to use any cleaners on a Corvettes fiberglass leaf springs till I joined C4 a few years and started reading.
Just wipe the fiberglass springs clean with a damp or water wetted rag.
Most cleaners will attack the fiberglass resin overnight or sooner.
Also never place a jack directly underneath a fiberglass leaf spring. If nicked by metal, the spring will fail or break in short order.
Old Jan 22, 2011 | 09:03 PM
northbender42
I cant remember what i cleaned it with but im sure it was with some kind of solvant.....damm i wiped it off rite off.... man that is sensitive stuff
i was wodering if it was becouse the susp, was non relaxed[after the polys went in] and the tires were toed in for a while after i lowered it to the ground
Old Jan 22, 2011 | 09:27 PM
No, it was the solvent that did the damage.
Old Jan 22, 2011 | 09:37 PM
STL94LT1's Avatar
STL94LT1
We can't even use soap to clean the rear spring? Also with the solvent, this is the first I've heard of this.
Old Jan 22, 2011 | 10:05 PM
Pete K's Avatar
Pete K
Neutral Ph soap is ok.
Old Jan 22, 2011 | 10:10 PM
Pete K's Avatar
Pete K
Dont click that pic link. It just tossed a virus on my laptop.
Old Jan 22, 2011 | 10:23 PM
northbender42
i am so sorry
Old Jan 22, 2011 | 10:24 PM
Thanks for the heads up again Pete.
almost clicked on his photo link.
Old Jan 22, 2011 | 10:42 PM
northbender42
I am so sorry about that i removed that message ASAP god i hate using image shack......anyone know a good place to store my pics for posting..
Old Jan 22, 2011 | 10:55 PM
The wife use "SmugMug" to store our photos.
Pete K. is going to be upset at you tonight for accidently uploading a Virus onto his laptop.
#$%^ happens on the internet.
Old Jan 22, 2011 | 11:14 PM
fc_soldier's Avatar
fc_soldier
I have a stock one if you wanna work something out.
Old Jan 22, 2011 | 11:51 PM
M. Schumacher's Avatar
M. Schumacher
I viewed the photo with no problems.
Old Jan 23, 2011 | 12:07 AM
383vett's Avatar
383vett
Yea, but now your hard drive is toast.
Old Jan 23, 2011 | 12:10 AM
M. Schumacher
my hard drive is fine.
To Rear spring broke.....
