Help removing stubborn half shaft
Old Jan 22, 2011 | 11:39 PM
Meloyelo90's Avatar
Meloyelo90
Default Help removing stubborn half shaft
Time to replace ujoints - cannot seem to get the half shaft removed. Straps are off, but it won't budge. Even pulled the knuckle away slightly but still no luck. First time trying to remove this from the car (it's a 95). Am I missing something ? Do you have to pry it out somehow ? I've seen other posts where people say it's easy but I'm not having any luck. Suggestions appreciated...
Old Jan 22, 2011 | 11:45 PM
John A. Marker's Avatar
John A. Marker
Pull the knuckle out while you have a small pry bar between the U-joint and the yoke. As you pull out on the knuckle, gently pry the U-joint from the yoke.
Old Jan 22, 2011 | 11:47 PM
M. Schumacher's Avatar
M. Schumacher
Yeah, they get stuck on pretty good over time. I would suggest prying it out of the diff end first.
Old Jan 23, 2011 | 12:03 AM
383vett's Avatar
383vett
Is your tie rod end disconnected from the knuckle so the knuckle assembly can move outward?
Old Jan 23, 2011 | 12:12 AM
85vet's Avatar
85vet
Cruise-In V Veteran
You have to pull the bottom of knuckle/rotor out and work the ujoint out.
Old Jan 23, 2011 | 09:11 AM
Meloyelo90's Avatar
Meloyelo90
Thanks for the replies, tie rod end is disconnected, there is some play in the knuckle so I'll try prying it out while pulling the knuckle away from the car.
Thanks again
Old Jan 24, 2011 | 10:12 AM
Meloyelo90's Avatar
Meloyelo90
Well the shaft is out finally, was stuck very badly. Now the joints will not come out of the shaft - tried using a vice and pushing through with a small socket on one end into a larger one on the other end but the first one I tried wouldn't budge. any secrets to getting these out ? I knew this stuff would be stubborn after 16 years...thanks.
Old Jan 24, 2011 | 10:29 AM
engle1147's Avatar
engle1147
You took the joint's 2 cap clips out/off right?
Old Jan 24, 2011 | 12:34 PM
85vet's Avatar
85vet
Cruise-In V Veteran
and PB Blaster
Old Jan 24, 2011 | 01:08 PM
Cyclonite's Avatar
Cyclonite
Hydraulic press...I actually broke a vise one time trying to do it via that method. I don't remember if it was the Vette or my truck, but the damn thing would not budge until I put it under a 20T press, and then still had to "tap" it to start it moving...
If you don't have a press take it to a machine shop and they can do it pretty cheap.
Old Jan 25, 2011 | 12:55 PM
M. Schumacher
You're not going to get enough force from a vise unless you have a monster. Ball joint press, hydraulic press, maybe a judicious amount of heat. They're probably going to let go with a bang when it happens so don't jump too high lol
Old Jan 25, 2011 | 04:20 PM
Meloyelo90's Avatar
Meloyelo90
Yeah clips are out, the vise felt like it was about to self-destruct so that's no longer an option. They just don't want to move. Maybe more PB Blaster and a tap or two, but it looks like a press is in order now.
Thanks again
Old Jan 25, 2011 | 11:29 PM
RUU's Avatar
RUU
I used a loaner ball joint/u-joint press - and they did let go with a lot of force & a bang!
Old Jan 28, 2011 | 08:49 PM
Elrick's Avatar
Elrick
Thanks again
advance auto will loan you their ball joint press if you put down a refundable deposit. it's really quick and easy with the press and then you can press in the new ones with it too.
Old Jan 29, 2011 | 08:48 AM
l98tpi's Avatar
l98tpi
Max G’s
You have probably already saturated with PB blaster or equivalent. You should be able to just heat up the yoke and tap the ujoint cap out. You may want to heat up both ends and tap on one then the other. Good Luck
To Help removing stubborn half shaft
