New
Old Jan 23, 2011 | 12:18 AM
Arnold87's Avatar
Arnold87
Default New
Hey guys. Im Arnold. I just got my first corvette last week. Its a 1987. Quick question....when i start it it wont start unless i give it a little gas and once it starts i have to give it a little more gas to keep it running but after that it runs great. Is this a concern or is it normal because of the age??
Old Jan 23, 2011 | 06:47 AM
steven mack's Avatar
steven mack
Sounds like your cold start injector is not working.The injector is connected to the bacck of the fuel rail to the bottom of the runners on the drivers side of the motor.
Old Jan 23, 2011 | 09:16 AM
twin540's Avatar
twin540
Welcome to the forum
JackDidley's Avatar
JackDidley
Drove mine for 3 years that way. Didnt bother me.
Old Jan 23, 2011 | 02:29 PM
jimmers's Avatar
jimmers
Welcome!
Old Jan 23, 2011 | 06:08 PM
John A. Marker's Avatar
John A. Marker
Welcome to the Forum.
If you can get your hands of a fuel gauge, attach it to the fuel rail (engine OFF). Then turn the key on and watch the pressure build....
1) does the pressure hold y/n
2) if the pressure drops quickly to zero within a minute then check fuel regulator and fuel pump
3) Do you know when the last time the fuel filter was changed?
Get back to us with more information when you can.
Old Jan 23, 2011 | 09:44 PM
Arnold87's Avatar
Arnold87
Thanks for the advice! I dont know when or if the fuel filter has been replaced. It has 60300 miles on it right now. The car was kind of slugish the first couple of days but its running great now.. i think it sat for a while. As a precaution im gonna change the oil and transmission fluid, change the spark plugs and replace and belts or hoses that look cracked or dry rotted...i also need to replace the weather stripping on the rear window.
Old Jan 24, 2011 | 07:35 PM
87RedVet's Avatar
87RedVet
I had the same problem with my 87. It only had 58,XXX miles when I got it. What helped mine was changing the fuel filter and removing and cleaning the throttle body. The throttle body passages were gunked up with carbon. Good luck with your vette. I have had mine a few years now and I have have been taught a great deal by the folks on this forum... Welcome and enjoy
Old Jan 24, 2011 | 08:31 PM
383vett's Avatar
383vett
Welcome to the forum. A lot of times, a gunked up throttle body will not let air past the blades and the motor will not start without some pedal. Remove your intake hose up to the throttle body, open the blades manually and squirt some throttle body cleaner in there. Use a toothbrush and you should get most of the gunk out. Squirt again, put everything together and start it up. The motor will smoke for a short while, but hopefully you problem will have cleared up. Willie
Old Jan 24, 2011 | 10:50 PM
Arnold87's Avatar
Arnold87
Thanks! Im off tomorrow so ill probally go outside nd give that try. This forum is great. This is the first time on the forum but i know how helpful it is because my stepdad was on here a lot when my mom had her '73 so i ws excited to be able to get on here
Old Jan 25, 2011 | 08:20 PM
j-wireman's Avatar
j-wireman
Welcome to the Forum, Arnold. There are a lot of experienced C4 owners here with lots of good information here. Ask questions. You'll get answers.
Best of luck with your '87.
Mike
'90 'vert
GO PACKERS
Old Feb 20, 2011 | 10:18 PM
Jvette73's Avatar
Jvette73
It's been a while since I posted here. Regretfully sold our '73 years ago. I'm Arnold's stepdad.
Arnold, since you havn't posted a pic of your vette yet, I thought I'd pin this one up for you. It's the one you sent me in a text message.
The car looks good. Have fun and be safe.
Old Feb 20, 2011 | 10:33 PM
87 vette 81 big girl's Avatar
Welcome !!
Great guys here on C4, many years of knowledge and experience here.
Enthusiasts, Real drag and road racers, Home mechanics, professional
mechanics, Race engine builders, transmission experts, differential experts
machinists, engineers, a few that actually Run on the Bonnevillesaltflats
with their C4 into the 200MPH club.......... and the list goes on.
Keep you proud of your C4 for years to come when you stop by often and participate with any of us here.
BR
Old Feb 20, 2011 | 10:34 PM
Jvette73's Avatar
Jvette73
For old times sake, here's a pic of the former '73 with me floggin it down the track at Cecil County Dragway. I won top eliminator that day. 13.30 @ 103
Old Feb 21, 2011 | 05:26 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Wow, There's a blast from the past! I grew up in Northern Delaware and CCD was one of the tracks we used to visit. Is it still going?
Old Feb 21, 2011 | 08:50 PM
Jvette73's Avatar
Jvette73
Yep. > http://www.cecilcountydragway.com/index.shtml
Old Feb 21, 2011 | 10:25 PM
Chapindad's Avatar
Chapindad
Things I have learned from my 87 over the last 3 years:
1) Replace the injectors with ones from F1C
2) Clean the TB and the Intake (took 3 cans of Carb cleaner)
3) Suck out the Brake and Steering Fluid and replace
4) Replace Brakes and Rotors
5) Start scouting for a Field Service Manual
6) If the tires are old then replace them before they shred
I love my 87 more than any car. Everyday is a joy to ride it and Every weekend is a joy to fix something.
To New
Old Feb 22, 2011 | 05:57 AM
HlhnEast's Avatar
HlhnEast
Welcome!!
Old Feb 22, 2011 | 06:04 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
Welcome. I am a proud aussie owner of an 87 convertible that spent the first part of its life in Japan. Great year.
Old Feb 22, 2011 | 10:31 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Thanks for the link, John.
