I finally had some time to swap out my Z51 spring for a softer base spring (NYR I think). It has a MUCH bigger arc - my Z51 spring is almost flat.
I installed the "2 above, 0 below" shim setup on the new softer base spring and put the brackets back on the RH and LH side and guess what happened....the brackets bottomed out when I tightened the bolts and there was still space left in the spring / shim area.
Basically, the NYR spring I used must have a certain shim count that is required to fill the finite space that the brackets provide. How do I find out what that is? My 1984 factory manual (purchased with the car in 1984) does not call out any differences in shims, etc.
It makes sense, the Z51 spring is much thicker than the base softer spring. When you put the NYR softer spring in place you need extra shims to take up the space. Just need to find out what that is. Anyone have any idea? This must be documented somewhere easy to get. Also, where do I buy shims? I'll look at cc and a couple of others. Thanks in advance.
Measure the thickness of the original spring and the shims and duplicate that thickness for your replacement spring and shims.
There are 4 thickness shims. 2 are in my post above and the other 2 are
14084056 - 1.72mm and 14093185 - 4.39mm
OR measure the gap that you have and fill that dimensionally. If you have to shuffle the stack to adjust height then do that.
You'll need to probably find these from a WTB in the parts section. You might try "indianavette" - I would think he should have! VanSteel - maybe?
C4 of Year Winner (appearance mods) 2019
It's looking like my RR is sitting 1/2" lower than the other side. Unless [bad] shocks can make that much difference, could you adjust one side accordingly? (move shims top to bottom)
I will look for evidence of de-lamination and I need to install new shocks that I've already bought.
It's a really annoying situation because of how often my left side pipe is touching the ground. It's gonna tear the cover up one of these days!
You guys probably tilt them anyway for circle-track racing, right?!
I have a "new" NYR and a "new" BMF and the difference in the cushion thickness at the mounting pads is something right at 7.14mm. The BMF isn't a Z51 early but it should be something very close I would think to what you need to get a correct attachment.
You should I guess be prepared for a dimension close to that when you're checking your parts for thickness.
The mount and shims need to be "equal"! The bolts at the ends are a different "conversation" but it would seem you've the right idea looking for maybe a spring issue. Shocks you would think are along "for the ride"!
That is very close to the gap I see right now. I will probably measure the "stack" of my original set up and do the match with the new NYR to see what shims I need.
I'm surprised information like this isn't in a matrix somewhere for folks to swap different springs in and out quick.
Now to start the shim search....
I measured the current Z51 setup including all the shims, isolators, etc. Then measured the thickness of the softer NYR spring at the mountings. Looks like I need about 6.5mm based on my non digital calipers. The 7.11mm measurement was just about right on the money.
I found shims on Ebay and have them ordered. Hopefully this week I can get this buttoned up.
