i can get aux fan to turn on by grounding green wire on passenger side of block but main fan doesnt turn on i ground the same wire and test for voltage at main fan motor and dont get anything i was getting ground there earlier no nothing..... i replaced the radiator fan control relay which seemed a lil burnt inside but still have no movement at main fan and aux doesnt come on unless i hook a ground to the green wire on passenger side of the block
If you don't get a answer in 24 hours bring your original post to the top again instead of starting a new one.
Gets too confusing when two posts on same subject are running at once
And you would prob get more attention if you put "fan don't run ' or "fan help needed" as your title
