I have a 96 CE coupe and just bought a set of black GS wheels that I hope to install in the next week or 2. I just got the car last week and just found out about LTPS in later C4's (prior vettes were an 86 and 80).
How can I tell if I have the LTPS system?
What do I need to pull from the old wheels and transfer to the new wheels? I assume the sensors are able to be moved to new wheels?
Thanks in advance,
If you have them they will be under the tire mounted with a big hose type clamp around the wheel with the sensor mounted to the band, each wheel has a different color, like yellow, red, blue and orange. If there not there you most likely do not have the system
Hey Joe, thanks for the quick reply. Any way to tell ahead of time, if I have the LTPS option? I don't have run-flats, if that's a sign.
Anything I can check with the LTPS light on the dash? If it comes on, or doesn't come on, when the key is turned, does that tell me anything?
My 95 was missing two of them and while driving after a few minutes the light would go on. the wheels will have a sticker on the that warns a person working on the wheels that the car has the system, so if they are factory wheels you could check. Good luck and don't be afraid to PM me for anything I can help you with neighbor.
Thanks buddy- I'll definitely reach out for help and you do the same. I'm recently back in the C4 world after a 5 year hiatus in a C3 so, I'm coming up with some questions here.... :o
