Dumb cooling system question
Old Jan 25, 2011 | 08:25 PM
ekess744's Avatar
ekess744
Default Dumb cooling system question
I am trying to finished off my carbed 383 build in my 88. I am running an intake manifold that locates a substantial amount of the coolant above the radiator cap.
I have decided to use a Moroso radiator hose filler (63745) install in the upper radiator hose to fix the problem.
http://www.moroso.com/catalog/catego...?catcode=29014
I am assuming that I need to relocate my expansion tank hose to the new fill point. If this is wrong, correct me.
My question is what do I do with the old filler cap and expansion hose outlet? Cap the outlet and put a high pressure radiator cap in the factory location?
Old Jan 25, 2011 | 08:37 PM
Lemme's Avatar
Lemme
St. Jude Donor '10
Why not just tee into the existing overflow hose and leave the standard cap and overflow hose in place.
Old Jan 25, 2011 | 08:41 PM
ekess744's Avatar
ekess744
I guess I was wondering if the system would still work properly having two locations trying to do the same thing.
Old Jan 25, 2011 | 08:57 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
It will be fine tee'ing into it. You have a pressurized source going to a non-pressurized location, so it will always flow toward the tank, even if both caps open.
Old Jan 25, 2011 | 10:26 PM
383vett's Avatar
383vett
I'm not sure why you need the hose filler. The TPI manifold held water above the filler cap too. The upper hose is the water return from the motor to the radiator. L98s are essentially self burping. I carbed my 84 for years and never had a heating problem.
Old Jan 26, 2011 | 01:34 PM
ekess744's Avatar
ekess744
This all started from what appears to maybe have been a faulty cap that has since been replaced...
I just assumed that having the filler at the highest point would be a better way of doing things
Old Jan 26, 2011 | 05:31 PM
383vett's Avatar
383vett
With the reverse flow Lt1 motors it is important. Your L98 should have no problems.
To Dumb cooling system question
