1990 Headlight Problem
Old Jan 28, 2011 | 11:11 AM
bsparky's Avatar
bsparky
8th Gear
Default 1990 Headlight Problem
Guys first time post, I have a 1990 Greenwood Corvette with a headlight problem, the problem is this:
Left headlight (driver side) works fine, Right headlight (passenger side) will not go up when turned on, but after I manually raise it, it will go down when lights are turned off. It may be a simple fix, I just want to know if anybody could tell me where to start first. Wiring, bad headlight module,gearing, etc? When I turn lights on I cannot hear the motor working at all.
Thanks in advance guys..
Old Jan 28, 2011 | 11:33 AM
Flame Red's Avatar
Flame Red
I believe your problem is that the plastic bushings are worn out. Not too hard to fix. There is a kit you can buy from the normal Corvette suppliers that contains fresh bushings. If you do a search on the bushings, you will also find a post with the part number for the bushing and you can get them from Home Repo - no corvette tax! Takes a couple of hours - I would do both sides while you are at it.
Old Jan 28, 2011 | 02:19 PM
bill mcdonald's Avatar
bill mcdonald
sounds like the bushings turned to powder, to me too. been there done that.
Old Jan 28, 2011 | 02:23 PM
UNCLEBILL's Avatar
UNCLEBILL
Zip Corvette supplier just listed how to replace bushings in their Tech section...got their e mail today.
Old Jan 28, 2011 | 02:40 PM
oldalaskaman's Avatar
oldalaskaman
at the end of his post it says he cant hear the motor running, if he was having someone else turn them on while he stood next to them he may just have a bad ground. if thats the case he may want to check for power at the plug.
Old Jan 28, 2011 | 07:30 PM
Wildride's Avatar
Wildride
Cruise-In II Veteran
There is a "Sticky" at the beginning of this Section which has in depth instructions on the headlight repair.
http://forums.corvetteforum.com/c4-t...air-w-pic.html
To 1990 Headlight Problem
