starter wire routing
Old Jan 29, 2011 | 01:50 PM
ekess744's Avatar
ekess744
Default starter wire routing
I am finishing up the the wiring on my 88 and I need to know the proper routing of the starter wire.
Also, where does the main ground conect to?
Just trying to make sure all my ducks are in a row before I hit the road.
thanks
Old Jan 30, 2011 | 01:25 AM
jfb's Avatar
jfb
The starter wire goes across the rear of the engine and down the right side to the starter motor. The large battery ground wire goes to a bolt below the left side valve cover with 4 other ground wires and the small wire off the negative battery terminal goes to a frame bolt on the right side of the battery.
