1990 Wont Start
Old Feb 1, 2011 | 02:38 PM
CAmaninacan's Avatar
CAmaninacan
Default 1990 Wont Start
I just replaced my transmission out of my 90 vette. And now it won't start. I am wondering if the timing is off. If so, how would I time it to the correct mark. Any help would be great!
Old Feb 1, 2011 | 02:58 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Does it crank and not fire or not crank?
Old Feb 1, 2011 | 03:00 PM
CAmaninacan
It cranks fine but it's not firing. I think the patterns off.
Old Feb 1, 2011 | 03:51 PM
engle1147's Avatar
engle1147
Make sure you connected everthing that you removed for the transmission work.
If your sure the timing is "off" - key the starter until you can get your timing mark on your balancer to line up with the 0 mark on the timing tab. Pull the distributor and drop it back in on number 1 (50/50 shot of getting it 180 out). Or be more exact and pull a valve cover, sparkplug(s)or use a piston stop.
Old Feb 1, 2011 | 04:10 PM
THE 383 admiral's Avatar
THE 383 admiral
even easier pull plug#1 <> TDC on tab.. use a straw or similar locate piston
Old Feb 1, 2011 | 08:54 PM
CAmaninacan
That worked thank you all so much. One more question you might be able to help me with, when i put it into reverse it shook a lot. I know i lost some fluid, could this be my problem?
Old Feb 1, 2011 | 11:04 PM
Muffin's Avatar
Muffin
Did the shaking stop? Did it shake in forward? Have you added fluid? Did it shake while in either Neutral or Park(out of gear)?
Old Feb 1, 2011 | 11:21 PM
CAmaninacan
I did add some fluid but realizes it leaks out of the dipstick tube gonna fix that tomorrow. Yes it only shakes when i put it in gear, doesnt shake if its in park or neutral.
To 1990 Wont Start
