To me the bottom line is;
Crossfire is cool because its Chevys first performance EFI and works pretty good in that light. But I dont see the Crossfire making more than 275 horse or making any meaningfull power over 5500 without a lot of work and money. The ECM can not manage enough valve timeing.
A 650, duel plane, pocket port 113s, cam and headers on the stock short block will make 75hp and 500+rpm more with a quick proven set up. I plan on retaining the ECM to control everything it does now, including WinALDL, except the fuel system.
I did a flat top 350 with stock 113 heads, comp 270h cam,650dp and rpm intake. It made 290 at the back tires. That would be a good bit over 300 at the crank.
That works out to at least 370 HP at the flywheel.
Figure 80-120 HP loss through the Manual trans or A4 auto, and the dana36 or dana 44 rear.
If you convert to a carb, your ecm will not be doing much. Obviously it will not control fuel management. Without an injector signal, it will not control spark either. I've been there, done that. The ecm sat in the cabinet after the conversion.
Quite a few people have gone well over 275 hp on the stock (ported) intake, myself included. I think the absolute limit for the stock intake is closer to 350.
hmmmm I was thinking the o2 sensor reports might talk to the ECS and pull out timing if the AFR is wack. I did not expect that the ECM/ECS would look at the injector feedback. How does that work? would it fix it if I duplicate the injector resistance of the injecter coil with a resistor to ground? Then there is the problem of finding the resistance of the energized coil. hmmm a 1 wire dizzy is lookin better. BTW thanks very much for the heads up
Without all systems functioning properly, the ecm will try to throw cels and go into a limp home mode or more likely just shut down. There definitely won't be any timing feedback from the o2 sensors. Just get a vacuum/mechanical hei distributor, rig up the fuel pump relay and good luck. Willie
I think that is probably pretty close. I an certain that you are one of most knowledgeable out there. The parameters that I am working in here is using the stock short block (less cam) and ECM. I really want to avoid having the ECM dictate valve timing. Or end up spending a lot of time piecing together a EFI system that I have very little experience with. I need to concentrate on the loose nut at the steering wheel.
