Trans leaking cooling lines
Old Feb 6, 2011 | 10:40 PM
CAmaninacan's Avatar
CAmaninacan
Default Trans leaking cooling lines
Well I finally finished putting my transmission in my 90. I started it up and looked under and realized I was leaking fluid. It's leaking from the coolant line on the transmission. Not around the threads but it did not seat properly so it leaks. Is there something I could seal it with? Its around the screwing in area. I want to try this Without pulling everything out. I don't have a lot of time on my hands. Thanks.
