Removing Corvette Breadbox!!
Old Feb 9, 2011 | 08:52 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Originally Posted by 86Vette350
Agent 86 where did you get the sheet of ABS at? thanks Looks real good!! goin to install a screen in mine, try that and see how it goes, flat panel touch screen
Got it a local Industrial plastic supplier.
http://www.ippnet.com/plastics.html
Should be something similar in every city, I would think.
Thanks to all that commented on my panel.
Old Feb 9, 2011 | 12:45 PM
pmihaltian's Avatar
pmihaltian
Slingshot
pmihaltian how much ya wanting for the panel? and do you have all the hardware to go with it? thanks it you want text me a pic of it at 501-281-6976 or email one at blueford_99@yahoo.com thanks again for all the help!!
PM and email sent.
Old Feb 9, 2011 | 07:56 PM
86Vette350's Avatar
86Vette350
Hey kiwi1 do you remember the company that made that glove box breadbox?? Looks awesome!!
Old Feb 10, 2011 | 02:14 AM
mgafun's Avatar
mgafun
Sorry, I don't know. Bought it from a former C4 owner in Denver who never installed it, and I lost his info when my laptop was stolen. I like it. Thanks for the compliment. Cheers.
Old Feb 10, 2011 | 09:15 AM
Tyloewen's Avatar
Tyloewen
In my 1985 Corvette the breadbox does not seem to open, its just there and looks like a airbag could be hiding in it. Does anyone know if there is an airbag inside because its so bulk and it must do something.
Old Feb 10, 2011 | 11:14 AM
gkrynick22's Avatar
gkrynick22
No air bag. The breadbox storage is after market, they are not supposed to open.
Old Feb 10, 2011 | 11:44 AM
383vett's Avatar
383vett
Here's mine holding an MSD box.
Old Feb 10, 2011 | 02:22 PM
Desert LT1 Vette's Avatar
Desert LT1 Vette
nice pictures older c4s do look better without it
Old Nov 7, 2012 | 11:46 PM
sparcnz's Avatar
sparcnz
I would like to know how one fits the standard vent. I pulled my breadbox out and found that the vent body is much too long to fit on the flat plate? Or was another vent used?
Was it modified in some way?
From Agent86's photos the plate sits on the outside of the mounting holes on the centre face plate and the outside.
Now to make a templete and check the fitting.
Regards.
Old Nov 8, 2012 | 01:34 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Pull that flex tube out.
Measure the before/after distance to approximate the necessary reduction in tube length
Cut the tube just after it bends outward toward the vent.
Cut it again a least 1-2" less that the amount needing to be removed
(Make your cuts in the low area of the accordian.)
Make 4 short radial slits in the tube.
This helps you push the tube (overlap it) back together.
If done correctly, you won't even need adhesive.
Install vent and new panel
Old Nov 8, 2012 | 03:35 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Here's mine, I covered it with black carbon fiber film. The one pic shows my vent hose I bought at Ace then spray painted the inside black so it didn't show through the vent.
[IMG][/IMG]
[IMG][/IMG]
Old Oct 10, 2013 | 08:04 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Originally Posted by kiwi1
I'll show these again. Formerly made in CA but no longer available.
To bad nobody wants to produce this, I know I would buy one, great idea.
Old Oct 10, 2013 | 12:00 PM
  #33
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I can't imagine how the designers would be inspired to "stick this big ol box thingy right here".
