Which O2 Sensor??
Old Apr 11, 2002 | 09:40 PM
Hi-psi's Avatar
Hi-psi
Default Which O2 Sensor??
Guys,
Got a '94 LT-1 6spd. A few weeks ago it coded a H63. Bought an O2 sensor today. Here's the problem. The car has 3 O2 sensors. One on the drivers side exhaust, then two on the passenger side, one before the cat, one after. Is there any way to tell which one is the bad one? I really don't want to buy 3 $40 sensors if only 1 is bad, and I don't want to have to keep trying different combinations of 3 until the code goes away. Thanks for any help.
Old Apr 11, 2002 | 10:01 PM
cesar's Avatar
cesar
Default Re: Which O2 Sensor?? (Hi-psi)
A C delco for sure i installed some bosh ran terrible change to delco runs great i was connnnnnvince the hard way
Old Apr 11, 2002 | 10:03 PM
Hi-psi's Avatar
Hi-psi
Ok,...just did some searching/reading. The way I understand it so far is the sensor on the drivers side and the one behind the cat on the passenger side are just there to basically tell the computer that the cats are working,...that the sensor that carries most of the workload and is much more common to go out is the one on the passenger side before the cat right?
BTW,...the one on the passenger side before the cat,...how the hell do you get it out? I don't have room to get a combination wrench in there and you can't use a socket on it unless you cut the connector/wires.
Old Apr 11, 2002 | 11:29 PM
LPDesRoche's Avatar
LPDesRoche
I dropped the exhaust when we did it on a friends 94. Drop the catback then unbolt the short tube from the exhaust manifold.
Old Apr 12, 2002 | 09:20 AM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
The car uses both O2's that are before the cats. The one after the cat does not make any difference on a 94.
You can get an O2 sensor socket with a slot in it.
Old Apr 12, 2002 | 11:59 AM
silver & red CE's Avatar
silver & red CE
Default Re: Which O2 Sensor?? (PeteL)
Listen to Pete, he's got it right. Don't waste a penny replacing the rear sensor, there's not any PCM check for it until 96.
Eric
Old Apr 12, 2002 | 02:56 PM
Hi-psi's Avatar
Hi-psi
Where?
Old Apr 12, 2002 | 02:57 PM
scorp508's Avatar
scorp508
Where?
Places like autozone will rent them for a $15 deposit that you get back. Or you can buy one for about $11 there.
Old Apr 12, 2002 | 03:31 PM
Red Dwarf's Avatar
Red Dwarf
I think your 94 is the same as 95. H63 is Bank 2, right front,Open circuit. :cheers:
Old Apr 12, 2002 | 03:39 PM
GlockLT4's Avatar
GlockLT4
Default Re: Which O2 Sensor?? (lou sylvestri)
I have a '94 ... and yes, the one behind the cat on the passenger side does nothing at all. You can unplug it and it doesn't affect anything (at least that my DataMaster logs showed). Don't bother replacing it. Just leave the one you have now in it's place to keep from having an exhaust leak :jester
DO change both of the others. It will save you enough gas to pay for them in the long run and your car will run better. Use GM ones if you can (order from Jeff Kopp - $26 each i think), or you can use Bosch if you have to (though I don't like them as much)
[Modified by Glock'94, 1:49 PM 4/12/2002]
To Which O2 Sensor??
