Coolant temp Issues
Old Feb 13, 2011 | 10:47 PM
Lawdog54's Avatar
Lawdog54
8th Gear
Default Coolant temp Issues
Hey guys I'm new to the site. I've been looking around and decided to pick ya'lls brains.
My 94 6-spd car is having issues. It starts fine when its not cold outside but dies about 4 times before it idles on its own. Once the car warms up it's hard to start. My temp gauge works fine but when i check the temp on the digital gauge it stays at 142 and the scanner says -40. Any sugestions?
Thanks,
Charlie
Old Feb 13, 2011 | 11:01 PM
rodj's Avatar
rodj
Try replacing the $14 CTS ( Coolant Temp Sensor ) on the water pump
All of engine operation is dependent on PCM receiving the correct engine temp from this sensor
Old Feb 13, 2011 | 11:03 PM
John A. Marker's Avatar
John A. Marker
Check fuel pressure at the rail. If pressure falls quickly or fails to build, it may be fuel pump.
Might check and or replace the coolant sensor.
Old Feb 14, 2011 | 01:55 PM
Lawdog54's Avatar
Lawdog54
8th Gear
Coolant sensor has been replaced. Still shows -40 on the scanner. Wire to the sensor broken or bad?
I'm going to try to trace it back when I get some time this week.
Old Feb 14, 2011 | 03:03 PM
94vettelover2's Avatar
94vettelover2
Old Feb 15, 2011 | 04:35 PM
sailorsteve's Avatar
sailorsteve
Wouldn't hurt to look for codes.
Those temp values you got seem like from another planet.
Are you sure the CTS is good and installed correctly?
Correct cold start means it runs ok in "open loop" mode, during which ECM uses assumed values and gets no input from CTS (and other sensors).
Old Feb 15, 2011 | 05:29 PM
rodj's Avatar
rodj
Temp values as written in the tune bottom out @ -40C
As the CTS has higher resistance with lower temp
185 Ohms @ 210F,
3400 Ohms @ 68F,
7,500 Ohms @ 39 F.
that temp reading from the PCM would indicate open circuit on CTS wiring
Old Feb 15, 2011 | 08:07 PM
Lawdog54's Avatar
Lawdog54
8th Gear
OK, open circut. Should I be looking for a cut or broken wire? Could it also be a bad connector?
Old Feb 15, 2011 | 08:17 PM
sailorsteve
Yes, it could be anything that interrupts the circuit. If you changed the CTS and saw the same results, it is not likely that both sensors are equally defective. Diagnostic info from the FSM would lead you step by step to the solution. Meanwhile, if you can pull a code, you can get some specific suggestions here.
Old Feb 15, 2011 | 08:58 PM
Lawdog54's Avatar
Lawdog54
8th Gear
Ok, thanks. I'll try to pull the code again.
Old Mar 29, 2011 | 01:04 AM
Lawdog54's Avatar
Lawdog54
8th Gear
Been a little more than a month but I finally got a little time to work on the car this past weekend. Unpluged the CTS and looked into the plug and noticed it was a little dirty. I traced the wires back and then noticed the plug had been replaced before, so at this point I just went ahead and picked up a new plug.
Got out there Friday evening and cut the wires and then soldered and heat shrinked it all back together and BOOM!!!! worked like a champ. No more Check Engine Light!!!
Gas milage has been up in the 28-30mpg while cruising in 6th gear on the freeway at about 64-67mph. No more hard starts when it warms up, and just seems to run better all around.
Thanks for all the sugestions guys. I'll definately be around the boards.
Charlie
Old Mar 29, 2011 | 08:16 AM
sailorsteve
Charlie
Glad to hear you fixed your problem!
To Coolant temp Issues
